v8turbo wrote:air filter is good, plugs are black and sooty due to running rich, I can not take it for a good run as it has no mot.
mr. pitts wrote:V8,
it's not the choke system sticking in the on position by any chance?
v8turbo wrote: if I wind the mixture screw in too much engine stalls, so I have turned it out as little as possible to get it to run on tickover at the leanest setting. The gastester as to be set at 2.0 and left for 10 mins, when put in the tail pipe this setting drops to 1.5 to 1.7?
Altransit wrote:It's been a long time since I messed around with a carburettor, but from what I remember, with a Weber, adjusting the idle screw, does nothing for the running mixture, as that is handled by a different set of jets entirely
