spot light mounting ..... info !
Postby GROWLER » Sun Jan 17, 2010 9:24 pm
hello you lot looking for some info on the best way to mount a set of 2 spotlights
to a mk5 transit ..... t reg 2.5di
anyone got any pictures or tips on the actual best location ....
info plzzz :mrgreen:
GROWLER
Re: spot light mounting ..... info !
Postby trigger » Sun Jan 17, 2010 10:38 pm
I just fixed mine to the front bumper (see avatar pic) :D
Mk5 Transit the daddy
trigger
Postby GUB84 » Sun Jan 17, 2010 11:36 pm
i bolted mine through the bumper but a bit of advice if you do put a piece of metal behind the bumper as mine shake when on a bumpy road
GUB84
Postby AlanN » Mon Jan 18, 2010 4:58 pm
I brought a length of aluminium bar, bent to shape and bolted it to the underside of the slam panel, then down to the front cross-member... I took the bolt out of the spot lamp and fitted it to the Ali and passed that through the grille. Bolted the lamps on. If you need a bit more reach, then a longer bolt with a length of tube slid over the top :D
Postby CJ-Entertainment » Mon Jan 18, 2010 8:07 pm
Looks good. do you have a pic of how to wire it up? and have you got a link to the lights.
CJ Entertainment
Your Professional DJ Service
0114 2499669 - 07892619432
CJ-Entertainment
Postby AlanN » Mon Jan 18, 2010 8:16 pm
I already had the wiring for the halos from the bumper lamps, so the halo where just tapped in, but Ive disconnected them since. The spots are to a 30A relay, must be a wiring diagram on here somewhere.
Lights where from fleebay, private sale
Postby CJ-Entertainment » Mon Jan 18, 2010 8:19 pm
AlanN wrote:I already had the wiring for the halos from the bumper lamps, so the halo where just tapped in, but Ive disconnected them since. The spots are to a 30A relay, must be a wiring diagram on here somewhere.
cool. do you have a dixi horn or somthing?
CJ Entertainment
CJ-Entertainment
Postby AlanN » Tue Jan 19, 2010 1:00 am
I did have some nice deep horns, but they didnt last five minutes, pumps fine, but the horns just gave up!!! :(
Postby fridge doctor » Wed Jan 20, 2010 6:17 pm
Mine has a roof rack. (wiring isn't a problem to feed up the inside of either side of the windscreen). I chose the roof because it gives a much better angle ... in fact from a couple of inexpensive lamps they light the road like daylight for way, way beyond the headlight full beam range, maybe 2/3 times further. Another reason I chose this position was ease of mounting and stability. At first I just riveted the back of the lamps to the roof rack, and this was perfectly acceptable on all but the worst roads... but, because in Britain you don't pay nearly enough road tax :evil: you have bad roads all over the place as soon as you leave main routes. So... I bought a couple of simple metal brackets, bent them to the required angle and riveted them to the back of the lamp, and the roof of the van, forming a triangle. Do use rubber washers and a bit of sealant where you have drilled into the roof, and all will be fine. Mine have been on 3 years and no leaks at all.
ps rivets don't work loose with vibration.
fridge doctor
Postby AlanN » Wed Jan 20, 2010 6:24 pm
I always thought roof mounted lamps cannot legally be operated from inside the vehicle... I remember one of my mates having to fit switched lamps to the outside on his hilux, or am I talking tosh :?:
Postby GUB84 » Wed Jan 20, 2010 8:21 pm
tosh it is then alan i always have lights on the roof of my landrovers and they are all switched from the inside
howz you anyway hope your ok
GUB84
Postby AlanN » Thu Jan 21, 2010 5:33 pm
Fine here mate, have you sorted that dent out yet :D
Postby captain hook » Thu Jan 21, 2010 6:28 pm
Roof lights are NOT legal to use on Public roads 8)
captain hook
