Starting problem
Starting problem
Postby pewe » Tue Jan 19, 2010 11:55 am
I have a starting problem with my 89 Diesel 2.5 (not banana).
Since I got it about a year ago it had always started with no problem on first turn (apart from when I had a blockage in the fuel line from the tank).
Last week - after lying up for a few weeks over xmas and the following cold spell - it started as usual without a problem, but cut out after a couple of minutes.
I have not been able to get it started since, although fuel is getting through to the injectors (I took a feed pipe off one of the injectors and when I crank the engine fuel does come out of it).
Can anyone suggest what might be preventing it starting or where I start looking for the problem.
pewe
Re: Starting problem
Postby KH_Towbars » Wed Jan 20, 2010 12:32 am
Have you tested the heater plugs?
2016 CUSTOM LIMITED LWB Shadow Black
2010 VW CADDY MAXI 1.6TDi
SOLD VW T5 102 SWB
R.I.P MK6 FWD 2.0TDDI Duratorq, EGR mod, K&N air filter, 16"alloys
KH_Towbars
Postby MrMPuk » Wed Jan 20, 2010 12:34 am
KH_Towbars wrote:Have you tested the heater plugs?
They don't have glow plugs.
Postby KH_Towbars » Wed Jan 20, 2010 12:55 am
oops, there I go again :!:
SOLD VW T5 102 SWB
KH_Towbars
