Mk1 and 2 independant front suspension conversion!
Re: Mk1 and 2 independant front suspension conversion!
Postby carnut1100 » Wed Jan 20, 2010 11:40 am
This idea is back in my mind big time...I think I might know where someone is wrecking a Mk5...and I would kinda like IFS and Rack&Pinion in my Mk2 truck...certainly know I want power steering in it!
1979 Mk2 Truck Project thread here
carnut1100
Postby jnwferguson » Wed Jan 20, 2010 9:31 pm
HI
does any one know if any body has fitted jaguar front suspension to a transit as I believe it will just bolt in as its on a subframe .
cheers jim.
mk2 camper
mk2 4x4
mk2 ci travelhome camper
the devil is in the detail
jnwferguson
Postby slogger » Sun Jan 24, 2010 5:59 pm
How is it mounted to the chassis , that has to be one of the best mods to do to a mk1 aside from putting in a di
slogger
Postby Luke » Sun Jan 24, 2010 8:29 pm
slogger wrote:How is it mounted to the chassis , that has to be one of the best mods to do to a mk1 aside from putting in a di
at the back :?: like this :arrow: Image
but the metal bit is now welded to the chassis rail :D
and the front pritty much on the origanal hangers :D
and the van this went on WAS a Di and that came OUT :lol:
Postby carnut1100 » Mon Feb 01, 2010 11:57 am
Haha! Mine's a 4.1 litre crossflow six, and if that changes at all it will only be for the EFi version of said crossflow six...
carnut1100
Postby Luke » Mon Feb 01, 2010 8:49 pm
carnut1100 wrote:Haha! Mine's a 4.1 litre crossflow six, and if that changes at all it will only be for the EFi version of said crossflow six...
one thing to think of is there's a bit less clearance with the ifs crossmember over the beam :!: :idea: :D
Postby pat stevens » Thu Aug 19, 2010 10:48 pm
i did this about 10 years ago to my lwb mk2 it took several atempts but the best way i found was to before i removed it from original van weld some bracing to the shocks so they are in the position needed then i cut out the inner wings and fabricated some turrets (simlar to mk 1 escorts) welded them into place then fitted it all together once ground and painted looked like they were supposed to be there .i hadthe van for a long time was regularly seen around nsva uksv shows and created a lot of interest. i must admit ive seen some pretty dodgy attempts of doing this some clearly unsafe with wheel angles totally wrong i fitted power steering on mine was well worth the effort especially as i had chevy v8 in it if your gonna do it make it safe take your time and check everything at least twice before you weld it all up. the difference is worth all the work if you get it right
if its got tits or wheels its always gonna end in trouble !!!
anyone can restore a van but it takes a real man to chop it up !!!
pat stevens
Postby Luke » Thu Aug 19, 2010 10:48 pm
have you got any pics of the van :?: 8)
Postby pat stevens » Thu Aug 19, 2010 11:58 pm
unfortunatly my pic collection has long gone but bob from uk streetvans got several
pat stevens
Postby 24v » Tue Dec 28, 2010 9:37 pm
I am in the middle of this conversion at the moment and see that the spindle to take the column is up against the filter which in turn is very close to the exhaust.Can I rotate the filter bracket to clear it?
Cosworth mk2 crew cab with IFS
24v
Cosworth Powered
Cosworth Powered
Postby Luke » Tue Dec 28, 2010 9:41 pm
24v wrote:I am in the middle of this conversion at the moment and see that the spindle to take the column is up against the filter which in turn is very close to the exhaust.Can I rotate the filter bracket to clear it?
i dont fully understand (got any pics) but do you mean the oil filter :?: behind it is the oil/water cooler (i never had this on) this will unbolt and screw the filter direct onto the block - you can get remote filer location kits if you need then you can either swap to a oil/air cooler :?:
Postby 24v » Tue Dec 28, 2010 9:46 pm
I have the oil/water cooler still attached and a leg that goes down aboct 3 inchs and the filter attachs to this.You have all this removed and the filter direct to the block?If so did you just connect the water pipes together?
(you know me and pictures it would be the middle of next week before I would get them on the page.... :oops: )
24v
Cosworth Powered
Cosworth Powered
Postby Luke » Tue Dec 28, 2010 9:50 pm
24v wrote:I have the oil/water cooler still attached and a leg that goes down aboct 3 inchs and the filter attachs to this.You have all this removed and the filter direct to the block?If so did you just connect the water pipes together?
yes - filter is directly onto the block, i got rid of the whole arm thing, i can't rememebr what i did with the pipes - i think from memory they come from the heater so you can remove one pipe and fit the other direct :? :)
i always intended to fit a decent oil/air cooler but never got round to it :)
Postby 24v » Tue Dec 28, 2010 9:59 pm
Without the cooler did you ever have any temp problems?
Also I am going to shorten the new column so as not to get the "notch" you were talking about.
Next are the shock mounts as I never took measurements from the original van.Would you have any suggestions?
24v
Cosworth Powered
Cosworth Powered
Postby Luke » Tue Dec 28, 2010 10:06 pm
for the column - once it aligned it using the welded up U/J it was spot on - brownysV6 has the welded u/j now :D not sure if shortning the column would do - i'd have to sit down and get my head round it :lol:
for the shock tops - personally i'd go to the trouble of getting a scrap van doing what i did and welding the shocks to the cross memeber then bolting that in yours to align the strut tops spot on ........... what are you using mk3 or mk4/5 :?:
