PLEASE PLEASE HELP.AT MY WITS END!!
Postby falsh » Tue Jan 26, 2010 3:32 pm
i have dropped a H reg 2.5d engine into my campervan.i have replaced fuel filter and have put manual primer pump on.The van will start and run lovely for a will then it will just conk out like its starved of fuel.it seems to me that the engine will run off the fuel in the filter but after that its like its just not pulling the fuel through.it has been standing for a while but i have taken off the filler cap to releave the pressure and still nothing.please please help this newbie!!!
Many thanks
falsh
Re: PLEASE PLEASE HELP.AT MY WITS END!!
Postby bazw » Tue Jan 26, 2010 4:30 pm
does the lift pump on the back of the block under the exhaust work? does it have one ?!!
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby falsh » Tue Jan 26, 2010 4:45 pm
I dont think it has a lift pump.someone told me it wouldnt need one.have i been mis informed?
falsh
Postby MinorMatt » Tue Jan 26, 2010 6:26 pm
possibly... do you have a lucas or bosch fuel pump?
When it conks out undo the tap on the fuel filter and see if some diesel comes out
Postby AndyG » Wed Jan 27, 2010 12:50 am
If it was a petrol, you'll need to remove the pick up gauze in the fuel tank :wink:
Postby ireland.1495 » Wed Jan 27, 2010 1:08 am
lift pump i think
try manual pumping it in
by pass filter and put a small one in instad and pump :D
ireland.1495
Postby GSXR » Mon Feb 01, 2010 6:04 pm
Not being a guru but the fuel is dropping back to the tank going by the explanation, the whole fuel line going to the filter has to be sealed to prevent air being drawn in...I have heard of one way valves being fitted inline, not sure if this is a cure but another choice maybe.
I discovered once a filter had been connected the wrong way round on an HGV, this in effect did the same thing, once the fuel lines were put the correct way round it was fine. Not sure if you can put it on wrong on a transit....
GSXR
