OIL IN WATER!
OIL IN WATER!
Postby mattyboy » Wed Jan 27, 2010 9:28 am
Hi folks, am looking at buying a transit 2001 on a y plate.
the only thing is that there is oil in the water :?
he says it drives fine and all that.
can anyone help me and tell me whats wrong or how to fix if i did buy the van and how much :?:
cheers matty
mattyboy
Re: OIL IN WATER!
Postby jay » Wed Jan 27, 2010 9:59 am
possible oil cooler failure but also usually gets water in the oil as well..or headgasket..Or very possible some dozy idiot has just put oil in the water expansion bottle.
mk1 connect tourneo
jay
Re: OIL IN WATER!
Postby selfwood » Wed Jan 27, 2010 9:03 pm
Had same fault with mine but left it too long...oil eventually knackered the radiator & various pipes aswell...£450 with everything raplaced with a 2nd hand oil cooler which i was told costs about £380 new....had to flush the header out once more after a weeks running in....working fine now...
selfwood
Re: OIL IN WATER!
Postby GBBiker » Wed Jan 27, 2010 9:08 pm
mattyboy wrote:Hi folks, am looking at buying a transit 2001 on a y plate.
cheers matty
Unless you are prepared to spend upwards of £500 straight away for parts alone, I'd be looking elsewhere.
GBBiker
Wrong Again!
Re: OIL IN WATER!
Postby darkbluevanman » Wed Jan 27, 2010 11:03 pm
selfwood wrote:Had same fault with mine but left it too long.....
If you had a banging headache for a week... how much longer would you leave that? :roll:
Smoke alarm doesn't work, batteries dead.. I'll do it next week!
Cut meself, it's started to go green and hurt, I'll leave it a few days to see if it clears up....
You've got until now to late November this year to check your anti-freeze!
darkbluevanman
Re: OIL IN WATER!
Postby GBBiker » Wed Jan 27, 2010 11:37 pm
:lol: :lol: :lol:
GBBiker
Wrong Again!
Re: OIL IN WATER!
Postby winterheating » Thu Jan 28, 2010 1:21 am
cheers matty
the question is how long has it been like this :?:
should be able to get an oil cooler for less than £150 at the very most 2nd hand, then fush the system out with washing up liquid(exellent degreaser) and should be fine, just get it at right price, head gasket is not very likely at all.
winterheating
Re: OIL IN WATER!
Postby selfwood » Fri Jan 29, 2010 6:34 pm
Its called having a job that requires constant use of your van...no van....no work.....no pay.....no good.....knacker
selfwood
Re: OIL IN WATER!
Postby darkbluevanman » Fri Jan 29, 2010 8:47 pm
Noooo.... ''£450 with everything raplaced with a 2nd hand oil cooler which i was told costs about £380 new....''
Van hire from £29 a day, 450 = about 15 days hire... even the drummer from Def Leppard could have done the repairs in that time!!
In the end it WAS off the road and cost you £450?, not arguing, just stating the obvious!
darkbluevanman
