2.5Di Non Turbo Engines
Postby matthew2riches » Wed Oct 21, 2009 12:50 pm
Hi,
This is from my donor van (A mk5 W reg):
And I'd like to know if the injectors would go into this (A mk5 P reg):
The injectors are shot in the P reg and I'd like to replace with the ones from the W reg if possible. They look the same engine appart from the air filter housing and the W reg has had the EGR mod done to it. The W reg also has a Lucas injection pump, the P reg has a Bosch - shouldn't make a difference should it?
Thanks in advance.
matthew2riches
Re: 2.5Di Non Turbo Engines
Postby madmark_50484 » Wed Oct 21, 2009 12:54 pm
Think you should find the injectors are in the same place and that top engine do you think it could be an old engine put in a new van :?:
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Postby matthew2riches » Wed Oct 21, 2009 12:58 pm
Hi,
May be an old engine in a new van but I'm not really bothered as that van is going to be scrapped.
It is exaclty the same engine I think appart from the fuel pump and air filter housing.
Non turbo as well... Injectors should be the same right???
matthew2riches
Postby madmark_50484 » Wed Oct 21, 2009 1:10 pm
Best bet is to chek the codes on them Minor Matt is an expert on injectors he should be able to advise.
I know the 2nd engine is a 70ps but the first one im not sure
Past
Present
www.busesuk.co.uk
madmark_50484
Postby GBBiker » Wed Feb 03, 2010 7:30 pm
madmark_50484 wrote:Best bet is to chek the codes on them Minor Matt is an expert on injectors he should be able to advise.
Sorry to bring up an old thread but the top looks like a 70ps so it should be a straight swap.
GBBiker
Wrong Again!
Postby psv-hgv-flt » Wed Feb 03, 2010 9:12 pm
no, that first pic is the old engine and will have the old type injectors in with the two nuts too bolt them down, the late (slim) bosch are diffrent with one nut to hold them in the head, diffrent pressures-injector pipes -and if i remember right four hole and five hole nozzle (as the crown of the piston's are diffrent) and the late engine will sound less noisey and smoother. :wink:
psv-hgv-flt
Postby madmark_50484 » Wed Feb 03, 2010 9:14 pm
I thought the early ones were different but wasn't sure still this post is like 2, 3 months old
Past
Present
www.busesuk.co.uk
madmark_50484
Postby GBBiker » Wed Feb 03, 2010 10:00 pm
madmark_50484 wrote:this post is like 2, 3 months old
But I like pictures of engines :mrgreen: :P
GBBiker
Wrong Again!
Postby matthew2riches » Mon Feb 08, 2010 5:12 pm
Pics are good. I'd like to produce a whole set of all the different engines fitted as standard to Transits for reference.
matthew2riches
Postby MrMPuk » Mon Feb 08, 2010 6:53 pm
matthew2riches wrote:Pics are good. I'd like to produce a whole set of all the different engines fitted as standard to Transits for reference.
If only someone had thought of doing that. :lol:
viewtopic.php?f=16&t=2550&start=0
Postby MIXA » Mon Feb 08, 2010 8:38 pm
The first engine is from a mk4 or very early 5 look at the thermostate housing early type the later as in pic 2 has the screw type
MIXA
Postby psv-hgv-flt » Mon Feb 08, 2010 9:25 pm
MIXA wrote:The first engine is from a mk4 or very early 5 look at the thermostate housing early type the later as in pic 2 has the screw type
late are bakerlite, early have got cav pump with coldstart pull-cable
psv-hgv-flt
Postby matthew2riches » Wed Feb 10, 2010 12:03 pm
I'm now going to sit on the stairs and cry my eyes out :cry: :cry: :cry: :cry:
My life is now meaningless :lol:
matthew2riches
Postby MinorMatt » Wed Feb 10, 2010 1:07 pm
all mk5 have bosch pumps with bakelite housings... it changed during mk4 production ;)
