JUST Blown my engine i think
Re: JUST Blown my engine i think
Postby madmark_50484 » Wed Feb 10, 2010 5:23 pm
When was the last time it was changed to when it went :?:
could you have an oil leak :?:
hows your water pump looking :?:
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Postby dazrecoverymad » Wed Feb 10, 2010 6:43 pm
water pump seems to be ok /in all honesty the belt probably hasnt been changed since new it is a p reg/does anybody know if it is important to reset the tappets after a cambelt and push rod change /ive noticed there a bit noisier than before not that much /would it affect anything or is it just a matter of being noisey /also what are the correct gaps?
dazrecoverymad
Postby MinorMatt » Thu Feb 11, 2010 9:23 am
yes you should redo the tappets.
Basically no 2 rods are quite the same so when you replace them then the valves will open at the wrong time and the wrong distance.
Doing the tappets will knock the noise down a bit and should improve the power and economy a little
Postby dazrecoverymad » Fri Feb 12, 2010 10:17 am
in that case does any body know the correct gap they should be set at?thanks
dazrecoverymad
Postby madmark_50484 » Fri Feb 12, 2010 10:30 am
Past
Present
www.busesuk.co.uk
madmark_50484
Postby paul_elwell » Fri Feb 12, 2010 10:51 am
Why did the belt loose teath? Old age probably.
Common way for them to fail
paul_elwell
