Transit central locking problems
Postby vanman41 » Wed Feb 10, 2010 9:16 pm
Hi Folks
I have a transit lwb 2000/350/90hp
I have been having problems with central locking system some time the backdoors will lock with the fob othertimes it won't i change the battery in the fob still this did help now the back doors are locked and can't be opened from the inside the passenger door and side work of the fob to top it all of the drivers door won't lock with the key
please help before i go nuts
vanman41
Re: Transit central locking problems
Postby ake » Wed Feb 10, 2010 9:18 pm
Your best bet is probably to get a new fob
Postby vanman41 » Wed Feb 10, 2010 9:22 pm
ake wrote:Your best bet is probably to get a new fob
do you know how i can get the backdoors opened as they are slamed locked won't open from the inside
vanman41
Postby jay » Thu Feb 11, 2010 12:13 am
unlock the doors from the drivers key lock
mk1 connect tourneo
jay
Postby vanman41 » Thu Feb 11, 2010 12:27 am
Hi
the back doors of the transit are worked by the fob there is no keyhole to open the backdoors the driver side door lock won't lock with the drivers key
vanman41
Postby ake » Thu Feb 11, 2010 7:40 am
Can you unlock with the key in the drivers door :?: If so turn it to unlock (clockwise) twice in quick succesion to unlock the back doors
Postby jay » Thu Feb 11, 2010 8:26 am
ake wrote:Can you unlock with the key in the drivers door :?: If so turn it to unlock (clockwise) twice in quick succesion to unlock the back doors
was what i meant..maybe the key is to worn to work the lock try the spare key or if no spare get your recut on a ford blank(get locksmith to cut the key and dont worry about chip as only useing it for door lock)
mk1 connect tourneo
jay
