unidentified part on smiley front
Re: unidentified part on smiley front
Postby Altransit » Fri Feb 12, 2010 5:47 pm
MrMPuk wrote:Yep, dry bearing. I think AndyG did a how to.
Thanks MrM, I was going to ask Andy how easy it was to get at the motor, keep forgetting though :roll: :oops:
Postby ZeldaTheWelder » Fri Feb 12, 2010 6:12 pm
Cheers :D for that if you find out could you let me no?
96 mk 4 smiley banana swb semi hi top
Mk6 swb low top with even more rust!
04 Connect T220 LWB.
ZeldaTheWelder
Postby Altransit » Fri Feb 12, 2010 6:13 pm
AndyG will be the man, I'll try and remember to ask him when he comes on later :D
Postby MrMPuk » Fri Feb 12, 2010 6:22 pm
Like I say, he did a how to!
Postby ZeldaTheWelder » Fri Feb 12, 2010 6:25 pm
Ok ill have a look for it. cheers
ZeldaTheWelder
Postby Altransit » Fri Feb 12, 2010 6:25 pm
MrMPuk wrote:Like I say, he did a how to!
Yes, and I did look, but I couldn't find it :?
Maybe use your magic? :wink:
Postby snax » Sat Feb 13, 2010 1:46 pm
This? ... viewtopic.php?f=31&t=12288
Hope it helps,
Regards S.
snax
Postby WildGoose » Sat Feb 13, 2010 6:01 pm
Trouble is having it running on speed 3 will burn the switch out leaving you with no fan at all.
Bugger.
I've been giving my busted heater resistor a damn good ignoring for 18 months, but might address it now.
Why does having only speed 3 burn the switch out?
WildGoose
Postby MrMPuk » Sat Feb 13, 2010 6:08 pm
WildGoose wrote:Why does having only speed 3 burn the switch out?
Because that is when it pulls the most current.
