How to wire extra hazard lights only (not indicators)?? Help
Postby Tran59 » Sat Feb 13, 2010 8:57 am
I would like to add two extra flashing lights at the top of my rear windows which flash only when the hazard warning lights are on. The problem is that I don't want them to flash when I use the indicators to turn, as they are 'emergency' strobe-type flashers.
Does anyone know if it's possible to tap into the rear indicators and/or hazard warning light switch so that the strobe lights only come on when all the indicators are flashing?
TIA :)
The best mods are the ones you don't see
Tran59
Re: How to wire extra hazard lights only (not indicators)?? Help
Postby ake » Sat Feb 13, 2010 10:18 am
Given the complex nature of the Can bus wiring on the MK7, it would be far easier just to use a seperate switch, avoiding the need to make an embarrassing warranty claim for a blown up BCM
Postby ireland.1495 » Sat Feb 13, 2010 11:25 am
easier just to use a seperate switch & flash relay
ireland.1495
Postby trigger » Sat Feb 13, 2010 12:21 pm
I would think you would have to run a wire and tap into the hazard relay as you cannot tap into the lights themselves as they would flash with the indicators
Mk5 Transit the daddy
trigger
Postby ake » Sat Feb 13, 2010 12:25 pm
trigger wrote:I would think you would have to run a wire and tap into the hazard relay as you cannot tap into the lights themselves as they would flash with the indicators
Not on a MK 7 you can't there is no hazard relay, its all done by the BCM :(
You would struggle to do this on a MK5 or 6 as the hazards and the indicators share a relay, I'm not saying it cant be done but it would require quite a bit of knowledge and a few relays
Like I said earlier a seperate switch is the easiest way, Also what about lighting regulations? Would having additional lights switched with the hazerds comply with all regs :?:
Postby ireland.1495 » Sat Feb 13, 2010 12:29 pm
ireland.1495 wrote:easier just to use a seperate switch & flash relay
12v bike flash relay & switch
did it a few times easy like extra spots
something like this
eBay item:
LIN12 Universal 6,12 Volt Indicator Flasher Flash Relay (#220472211469)
ireland.1495
Postby AlanN » Sat Feb 13, 2010 1:19 pm
Why not just use a relay off the supply to the hazard flasher bulb on the dash!!!, vertually no current from the relay.
Postby captain hook » Sat Feb 13, 2010 2:21 pm
I'm guessing you've never played with Can-bus or BCM modules before :shock: :?
Leave it alone....Seperate switch is the way forward :wink:
captain hook
Postby MrMPuk » Sat Feb 13, 2010 2:24 pm
Not sure what the French vehicle inspections are like but this would mean an MOT failure in the UK as well if they were wired into the hazard circuit.
Postby trigger » Sat Feb 13, 2010 2:31 pm
You mean they have Transits in France? i thought they all drove Renault Traffics
trigger
Postby AlanN » Sat Feb 13, 2010 2:52 pm
Yes I have... but not on a transit, whats the problem with them Barry :?:
OK then, photo electric switch, not sure where you could hide that in the button thou :lol:
Postby ake » Sat Feb 13, 2010 3:26 pm
The strobe lights would require a constant 12v supply, not one that flashes on and off :?
Postby Tran59 » Sat Feb 13, 2010 8:52 pm
Many thanks for your words of wisdom, everyone. I think all things considered, I will play safe and go for the separate circuit controlled by a switch.
Tran59
