Stormdog wrote:Well i am a little embarresed! When i installed the new flywheel, i checked the diameter, the fitting to the crank, the clutch fitment and even the ring gear was all the same...... But neglected to check the segments for the crank sensor pick up! I removed one with large segments and stupidly refitted one with small segments! So the riddle is solved to the cost of me having to remove said gearbox and flywheel and replace the flywheel with the correct one! A job for tomorrow i think!
Many thanks to all of you who took the time to throw me some ideas.
Ian
