ECU help.
ECU help.
Postby StuartB58 » Mon Feb 15, 2010 6:33 pm
Hi I'm new to Transits and was hoping someone could explain a few things for me. I've read on this site about mapping etc so now I need to know what this means. Are we talking about the ECU? The problem I have is the Mk 5 I've just purchased is governed so I'd like to get a little more out of it. There's a forum member breaking an identical van and I was wondering if theres something I can easily swap from his van to mine to give it a bit more top speed.
Thanks for any help I receive,
Stu.
MK6 Twin wheel 2.4 in white
Ford where rust is NOT an option.
StuartB58
Re: ECU help.
Postby madmark_50484 » Mon Feb 15, 2010 9:50 pm
When you say goverened do you mean it won't go above 3500 revs or is it just speed restricted :?:
AndyG is the man to ask as he is the EPIC specialist at a guess if it is actually goverened you would most likely be able to swap the ECU's around and bob's your uncle but that is a guess
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Re: ECU help.
Postby MinorMatt » Mon Feb 15, 2010 10:01 pm
hang on a sec mark...
Stuart, has your van got a turbo?
Re: ECU help.
Postby MrMPuk » Mon Feb 15, 2010 10:03 pm
MinorMatt wrote:hang on a sec mark...
Look in the sig.
Re: ECU help.
Postby MinorMatt » Mon Feb 15, 2010 10:09 pm
wasnt there a minute ago... :?
You can get chips to give an extra 30ish HP for the turbos
Re: ECU help.
Postby MrMPuk » Mon Feb 15, 2010 10:12 pm
MinorMatt wrote:wasnt there a minute ago... :?
It was, was there before he made this post.
Re: ECU help.
Postby MinorMatt » Mon Feb 15, 2010 10:13 pm
must have missed it then :?
Re: ECU help.
Postby dibs » Mon Feb 15, 2010 10:56 pm
What is your top speed at the moment? You can use the gearing calculator and the diff ratio to work out what it should be at about 4000rpm. See Useful info on the board index :)
1990 LWB Mk3 twin wheel 190 minibus (My favourite but stolen)
1998 LDV Convoy Ford DI engine but... yuk, yuk, yuk (bought in desperation, sold 2 months later)
1997 SWB Mk5 minibus (Great but small)
2001 LWB Mk5 TD 100ps Minibus (hmm..)
Get me to that gig!
dibs
Re: ECU help.
Postby psv-hgv-flt » Mon Feb 15, 2010 11:09 pm
dibs wrote:What is your top speed at the moment? You can use the gearing calculator and the diff ratio to work out what it should be at about 4000rpm. See Useful info on the board index :)
auto are normaly 4.11 diff he wants to put some 100ps injectors in and blank egr off. look hear. http://www.uniteddiesel.co.uk/stanadyne ... ectors.php
33710 brown spot. that will make a lot of diffrence :wink: oh, and change it to manual.
psv-hgv-flt
Re: ECU help.
Postby StuartB58 » Mon Feb 15, 2010 11:25 pm
Hi many thanks for all the replies guys. :D
Top speed is around 50mph.
Details from the Ford site :-
Build Date: 04.05.1999
Vehicle Line: Transit 95
Cab Style: Regular Cargo Van
Series: 150S
Engine: Diesel 2.5T (85PS)
Transmission: A4LD (M)
Drive: RHD RWD
Axle Ratio: 4.63
108000 miles.
I wanted an automatic as I'm slightly disabled and have problems with my left leg and back also my wife only has an auto licence :oops:
So looks like I'll try the ECU first see if that helps, can anyone tell me where I'll find it and is there only 1?
StuartB58
Re: ECU help.
Postby MinorMatt » Mon Feb 15, 2010 11:28 pm
That should be good for 90ish
when you turn the ignition key, but before starting is there a red light with a picture of an engine? Does it go out immediately/after 5 secs or not at all?
Re: ECU help.
Postby psv-hgv-flt » Mon Feb 15, 2010 11:31 pm
StuartB58 wrote:Hi many thanks for all the replies guys. :D
Series: 150S
Drive: RHD RWD
Axle Ratio: 4.63
108000 miles.
i see, its a 150 model but should still do more than 50 :( blank egr and 100ps injectors first. :wink:
psv-hgv-flt
Re: ECU help.
Postby MinorMatt » Mon Feb 15, 2010 11:35 pm
if its only doing 50 it wouldnt suprise me if its in limp home and someone removed the warning bulb - hence the earlier question
Re: ECU help.
Postby psv-hgv-flt » Mon Feb 15, 2010 11:37 pm
when reved up, is it only 2000 max rpm (if its got a rev counter.??)
psv-hgv-flt
Re: ECU help.
Postby TimothyUA » Tue Feb 16, 2010 1:10 am
I have a similar problem, but goes aroun 80 mp/h, converted from Epica to bosh mechanics,hate the way it drives(((
TimothyUA
