reg check
reg check
Postby vinny55 » Mon Feb 15, 2010 9:03 pm
specs on this reg please p234pma thanks
vinny55
Re: reg check
Postby psv-hgv-flt » Mon Feb 15, 2010 9:07 pm
vinny55 wrote:specs on this reg please p234pma thanks
Transit 95, Diesel 2.5T (100PS), Diamond White 73
VIN Number: SFALXXBDVLVU40196
Registration Number: P234PMA
Registration Date: 01.07.1997
Registration Country: GB
Primary Features
Build Date: 20.03.1997
Vehicle Line: Transit 95
Cab Style: Regular Cargo Van
Series: 150L
Engine: Diesel 2.5T (100PS)
Transmission: 5-Speed Manual - MT75
Drive: RHD RWD
Axle Ratio: 5.14
Emission: 95 EEC Light Duty Truck
Territory: (+)"GB"
Paint: Diamond White 73
Interior Fabric:
©Copyright, Ford Motor Company 1994
:wink: :wink:
psv-hgv-flt
Re: reg check
Postby vinny55 » Mon Feb 15, 2010 9:45 pm
thanks; with everything out it comes in at 3100kg and is taxed hgv put in higher diff now it will run all day on m/way at 85- 90 and still has more to go.
vinny55
Re: reg check
Postby MrMPuk » Mon Feb 15, 2010 9:47 pm
3100kgs is the max loaded weight and it shouldn't need to be taxed as a HGV.
Re: reg check
Postby vinny55 » Mon Feb 15, 2010 9:55 pm
no 3100kg empty x cop van bigger springs wheels svo
vinny55
Re: reg check
Postby MrMPuk » Mon Feb 15, 2010 10:02 pm
vinny55 wrote:no 3100kg empty x cop van bigger springs wheels svo
The van is a 150 so the Gross Vehicle Weight is 3100kgs, empty it will be under 2000kgs.
Re: reg check
Postby GBBiker » Mon Feb 15, 2010 10:38 pm
Not being an ex Police van it won't Mike.
They are spec'd up to about 4250kg GVW due to the bullet proof armour plating :wink: That alone weighs almost a ton :!:
GBBiker
Wrong Again!
Re: reg check
Postby MrMPuk » Mon Feb 15, 2010 10:40 pm
That would be a 230 though not a 150.
Easy way to tell though, is it a Twin Wheel Hi-Cube?
Re: reg check
Postby MinorMatt » Mon Feb 15, 2010 10:59 pm
I thought the gross vehicle weight of a 150 was 3300kg.
GBBiker, the plod often did have them, but being law abiding they were 230's (as MrMPuk says) not 150s!
Just a thought vinny, have you got that 3100kg fiigure from the vin plate in the passenger footwell?
Re: reg check
Postby GBBiker » Tue Feb 16, 2010 7:00 pm
MinorMatt wrote:I thought the gross vehicle weight of a 150 was 3300kg.
Some forces had 150s with the single rear wheels and had them uprated accordingly, hence the HGV tax band.
GBBiker
Wrong Again!
Re: reg check
Postby vinny55 » Tue Feb 16, 2010 8:38 pm
2" armour to sides 5 layer windscreen 2" armour floor, wheels run flats + rims 1" wider clutch to edge of flywheel (£ 450 for clutch) springs 100% bigger anti roll bars front and back, lexan side windows 25% extra boost on turbo 2300 revs 55 mph in 5th .3100kg weighbridge weight empty done for dvla to get hgv tax off but they said no
vinny55
Re: reg check
Postby vinny55 » Tue Feb 16, 2010 8:44 pm
ps it says 150 on vin plate
vinny55
