Lack of power to the solenoid - smiley 95
Postby transit666 » Fri Feb 19, 2010 8:48 pm
hi all.
Small problem of starting my van is ,
To start it i have turn the key on at the dash . lift the bonnet..
Stick a postive jump lead on battery and touch the small connector on the solenoid to start it .
Has anyone had this problem ? not sure if its a break in the wire , but it seems to lost all power .. hmmm...
Allso the orange light came for abit today while i was driving it then went off ? but not overheating .. hmmm...
Has trip the immobiliser out of action , blocking it from starting in the correct way... :?
When the keys turns the starter relay clicks and the solenoid allso ....
Cheers Transit666. :)
THE GLASS IS EMPTY AGAIN !!!!!!!!
transit666
Re: Lack of power to the solenoid - smiley 95
Postby jimllshiftit » Fri Feb 19, 2010 8:58 pm
It may be of no help at all but I had a similar problem with my van of a similar vintage. I could get it to run if I fired it up on easy start then, apparently it had enough current to keep the solenoid open.
I didnt make the repair but from memory the guy who did mentioned something about a dry joint on the ignition barrel. It might be worth a look.
Good luck and I hope you find the fault.
jimllshiftit
Postby transit666 » Fri Feb 19, 2010 9:09 pm
HI, cheers for the tip , i look into that , sure its some stupid ,as its been runnin fine for last 4 yrs . no problem ...
Cheers Transit 666 .. :?
THE GLASS IS EMPTY AGAIN !!!!!!!!!!
transit666
Postby transit666 » Sun Feb 21, 2010 6:24 pm
hi all ,
Ive taken the bull by the horns today !!!! and snapped them off !!!
Taken the the cowling off and expose the the big black plug which goes to the ignition barrel.
Then run a wire from the solenoid small connection into bulkhead to the big black connector .
Theres a orange and white wire on the low power side. stuck the wire into there , and guess wot !
Magic happen : it starts on the key .... everytime .. problem solved .. well for now ...
Ps . i had a vauxhall corse combi , years ago someone seem to do the same thing , thats were got the idea from in the end ..
Live and learn all the time !! TRANSIT666......
Now i am off to do cartwheels !!! :lol:
transit666
Postby bortaf » Sun Feb 21, 2010 11:51 pm
not sure what van you have but did you check the starter relay on the side of the battery tray ?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby transit666 » Mon Feb 22, 2010 8:04 am
hi, yes i have had alook at that starter relay in yellow and the van is a 1995 swb , and taken it to bits to check , seems to click but maybe something else has blown in it , i looking out from another one from scrappy s ... as a replace part . :)
I think that problem with this . ..untill then the the extra wire .. ive fitted will have to do ..
Ps . anyone who got a spare yellow starter relay for sale for the above , give us a pm on the price etc ..
CHEERS
Transit666 ... 8)
THE GLASS IS EMPTY AGAIN .......
transit666
Postby bazw » Mon Feb 22, 2010 9:31 am
i thought the starter relay was the big black one in engine bay to left of engine !! about 3" tall and 1.25" square
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby transit666 » Mon Feb 22, 2010 8:00 pm
Yes i know were the solenoid is on the side of the starter... :o
but as the other member said before hand ,
theres a starter relay hidden behind the glovebox next to the control mode box . thats what we talkin about ... which allso part of the starting side which is could be faulty ..
Ive allready replaced the starter motor , so fault is not there....
Transit 666. 8)
transit666
Postby bazw » Mon Feb 22, 2010 8:03 pm
i was not thinking of on the starter but on the inner wing , do they not have a 50 amp relay to drop the load on the ignition switch still?
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Altransit » Mon Feb 22, 2010 8:24 pm
bazw wrote:i was not thinking of on the starter but on the inner wing , do they not have a 50 amp relay to drop the load on the ignition switch still?
If its the one attached to the side of the battery tray,with a cover over it, then mine has one :D
Postby bazw » Tue Feb 23, 2010 2:44 pm
:wink:
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby GBBiker » Tue Feb 23, 2010 2:55 pm
Yip! That's where my starter relay is too. Not 50A though, it's rated at 80A.
GBBiker
Wrong Again!
Postby transit666 » Tue Feb 23, 2010 8:44 pm
oh yes!!!! mines there too!!!
Funny enough i did look at the fusebox a couple weeks ago .. (quickly)
its got a blue fuse and a clearish yellow looking one to the front of the box , not sure of the ampish... 50-60 ?
looking close at it there don't seem to be the metal strip across .. Hmmmm i think that may be a blown fuse .
Try to pull it out , but does'nt shift to get a better look .
Do you have to use pilers on to remove ?
It must have blown when i try to move it on the key when the battery was just about to die..
Hmmm ......
Cheers guys ..
Transit666. 8)
THE GLASS IS EMPTY AGAIN !!!!!!!!!!!!
transit666
Postby Frag » Tue Feb 23, 2010 9:46 pm
transit666 wrote:oh yes!!!! mines there too!!!
Hmmm ......
Cheers guys ..
Transit666. 8)
The fuses you mean are bolted through the sides,easiest to remove battery to gain access. :idea:
Frag
Ford Technician
