Can I fit a rev counter?
Postby dirtydog » Sun Feb 21, 2010 1:34 pm
Ok let me re-phrase that question, I guess most things can be done with time money and patience but how easy would it be to fit a rev counter to my Transit as it doesn't have one at the moment?
dirtydog
Re: Can I fit a rev counter?
Postby dibs » Sun Feb 21, 2010 1:57 pm
1990 LWB Mk3 twin wheel 190 minibus (My favourite but stolen)
1998 LDV Convoy Ford DI engine but... yuk, yuk, yuk (bought in desperation, sold 2 months later)
1997 SWB Mk5 minibus (Great but small)
2001 LWB Mk5 TD 100ps Minibus (hmm..)
Get me to that gig!
dibs
Postby bazw » Sun Feb 21, 2010 3:25 pm
knowing what yo have would help just a bit :wink:
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby dirtydog » Sun Feb 21, 2010 4:53 pm
My God that's a long thread and i'm still no clearer on what I need to do :roll:
dirtydog
Postby dirtydog » Sun Feb 21, 2010 4:56 pm
bazw wrote:knowing what yo have would help just a bit :wink:
Oh yeah I guess that would be useful :lol:
Its a 2000 mk5 2.5 TDi with just the speedo in the centre.
dirtydog
Postby GBBiker » Sun Feb 21, 2010 6:01 pm
You have a TURBO diesel WITHOUT a rev counter??????? :shock:
GBBiker
Wrong Again!
Postby dibs » Sun Feb 21, 2010 7:34 pm
I've just ordered a Mondeo dash (from x reg mk2) to fit in my 2000 Mk5 turbo diesel. I'm hoping it will just plug in and work. Should arrive early this week, I'll let you know how I get on.
It seems like it's a bit hit and miss as to whether all the gauges work, so fingers crossed. I know the dash comes out with out removing wheel or light stalks so not too much trouble to find out. The most important thing appears to be the alternator ie 3 wires one of which sends the signal to rev counter.
Trip reset right side of speedo (under 150 mph) = electronic speedo. Yours is almost certainly this one.
left of speedo = cable driven
Get me to that gig!
dibs
Postby dirtydog » Sun Feb 21, 2010 7:36 pm
GBBiker wrote:You have a TURBO diesel WITHOUT a rev counter??????? :shock:
Uh huh
here's the spec of mine
Primary Features
Build Date: 01.03.2000
Vehicle Line: Transit 95
Cab Style: Regular Cargo Van
Series: 100S
Engine: Diesel 2.5T (85PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 4.56
Emission: 97 EC LDT Requirements
Territory: (+)"GB"
Paint: Diamond White 73
Interior Fabric: Windrush G-C
dirtydog
Postby dirtydog » Sun Feb 21, 2010 7:44 pm
dibs wrote:I've just ordered a Mondeo dash (from x reg mk2) to fit in my 2000 Mk5 turbo diesel. I'm hoping it will just plug in and work. Should arrive early this week, I'll let you know how I get on.
Just been out to check and the trip reset is on the right of the speedo
Yeah please let me know how the dash swap goes
dirtydog
Postby dibs » Sun Feb 21, 2010 8:31 pm
Keep your eye on ebay for dash. Lots of Mondeos being broken - not always listed as separate parts.
Get me to that gig!
dibs
Postby trigger » Sun Feb 21, 2010 9:00 pm
I've seen turbo diesels without rev counters, they didn't all have them
Mk5 Transit the daddy
trigger
Postby dirtydog » Sun Feb 21, 2010 9:05 pm
I used to drive a T reg turbo for the company I used to work for and that didn't have a rev counter either
dirtydog
Postby familybanger » Sun Feb 21, 2010 9:25 pm
I got some mondy clocks if your interested, not sure what model they off though as was given them with a van.
PM for details :)
familybanger
Postby dibs » Thu Feb 25, 2010 3:04 pm
My :( rev counter doesn't work. The one I've tryed to put in was only made a month or two after the date on my original speedo (Feb 22nd 2000 & May 22nd 2000) so thought it might work.
Rev counter does move a bit, but flicks straight to 6000rpm when ignition on. Took the needle off and reset to different position, but it will only read 1000rpm above idle, then nothing :( I've hard wired the counter to test it out of the cluster but same result. Code on the counter is 97bp. Must be calibrated on a different scale or something?
Sticker on the side of the rev counter reads: NEW CAL 2, 97bp 7360CB, 22/5/2000, GOOD
I've read everything I can find on this site (including the 14 page thread!). Did someone work out you need a pre '98 electric speedo for it to work right or am I just making that up :?: :?
Might work for someone else so will probably stick it on ebay.
Get me to that gig!
dibs
Postby jay » Thu Feb 25, 2010 7:41 pm
dibs sounds like your rev counter clock is knackered..you got a 3 wire alternator havent you??
mk1 connect tourneo
jay
Users browsing this forum: Midis
