Central locking remotes
Postby 100 T280 » Wed Jun 21, 2006 9:37 pm
I've read a post somewhere (can't find in now) re the above which differs from the instructions I got with a new remote fob. The instructions I got were to switch the ignition on and off eight times, the last time leaving the key in the on (II) position. (Locks start locking / un-locking) then press any button on the remote, then turn off the ignition. This works but I can only get one remote to work at any one time, aparantly up to 4 can be programmed. I've tried pressing the buttons on each of my three remotes, but only the first one pressed will the work :evil:
...anyone know the way round this???
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby MrMPuk » Wed Jun 21, 2006 9:42 pm
Did you program them all at the same time and did it confirm the programming?
The instructions are here
Postby 100 T280 » Wed Jun 21, 2006 9:47 pm
Have just found same instructions :oops: :oops: :oops:
Sorry. Yes I tried them all consecutively, and two of them simultaniously with no joy, only the first one pressed will work :shock:
100 T280
Postby motorwise » Wed Jun 21, 2006 10:21 pm
the procedure in the link has never worked for me (I think it's off TIS but it's wrong)
the way you've done it sounds right - this is how I've always done it :-
do the ignition on and off trick eight times leaving the ignition on pos 2 - the doors will lock then unlock - press button on first remote - doors will lock then unlock - press button on second remote etc - switch off ignition when finished with all remotes
is this exactly how you did it?
http://www.motorwise.net
motorwise
Postby Nighthawk » Wed Jun 21, 2006 10:31 pm
The correct and published method of programing the fob is
turn the ignition from off to on 8 times within 10 seconds ending up with the battery light (ign On) ON
the vehicle will confirm it's entry into learn mode by locking and unlocking the doors
after it's finished doing the locking bit
press any button on the fob
the vehicle will then confirm that it's learnt the code by doing the magic locking thing again :)
when thats finished press a button on the OTHER fob
the vehicle will now cycle the locks for the 3rd time
turn off the ignition and the vehicle will cycle the locks for the 4th and last time.
leave the vehicle alone for 30 seconds or so and then test operation of both fobs, I favour using 1 fob to lock and double lock and then the other to open load area and then front doors
Hope that helps.
Transit.........Job done
Nighthawk
Postby 100 T280 » Wed Jun 21, 2006 11:17 pm
The way you describe it MW, is the way that I've been trying...but, no luck :( . I'll try again tomorrow, I'll try your method Nighthawk, will let you know....cheers all.
100 T280
remotes
Postby tango » Fri Jun 23, 2006 3:21 pm
nighthawks instructions are spot on thats how i did mine
Tango 59[color=#FF0000][/color]
tango
Postby madmark » Fri Jun 23, 2006 3:29 pm
nighthauk is the man in the know! :wink: he is a godsend to this forum! :) :)
Postby MrMPuk » Fri Jun 23, 2006 7:38 pm
It may well have something to do with the year of the van because the other details that have been posted were proved to have worked.
Postby motorwise » Fri Jun 23, 2006 8:09 pm
MrMPuk wrote:It may well have something to do with the year of the van because the other details that have been posted were proved to have worked.
what year of van did you try it on? - there could well be two procedures that both work as you say according to the age of the van
motorwise
Postby MrMPuk » Fri Jun 23, 2006 8:11 pm
I didn't try it, I posted the procedure from the TIS onto here and the person that tried it said it worked.
Postby motorwise » Fri Jun 23, 2006 8:15 pm
MrMPuk wrote:I didn't try it, I posted the procedure from the TIS onto here and the person that tried it said it worked.
oh right - still no harm in try both ways - one or the other will work :wink:
motorwise
Postby MrMPuk » Fri Jun 23, 2006 8:17 pm
Or do it the way Geoff says and keep turning the key frantically till the van locks and unlocks! :lol: :lol:
Postby motorwise » Fri Jun 23, 2006 8:34 pm
MrMPuk wrote:Or do it the way Geoff says and keep turning the key frantically till the van locks and unlocks! :lol: :lol:
that'll do it :lol:
motorwise
Postby Nighthawk » Fri Jun 23, 2006 9:36 pm
Transit 2000 has always used 8 turns on the ignition though, and still haven't found an old edition of TIS that says otherwise for it,
Some of the carlines use fewer turns though.
A consolidated TSB was released to dealers in 03 iirc which gave details of how to program ALL the radio frequency remotes in use at the time.
Nighthawk
