Timing belt or "kit"?
Postby trippydog » Tue Feb 23, 2010 4:14 pm
Trying to sort my probs I'm going to have a look at the timing and makes sense to change the cam belt anyway as no idea when it was last done.
Before I buy a belt I just wondered what people's thoughts were spending the extra 30-40 quid and replacing the tensioners & rollers.. is that normally needed?
Cheers.
Former Van: '93 190 TD LWB High Top... Ex Police Riot Camper. Sad to see her go.
Check out our site, Go On Go Out if you are looking for live music in Portsmouth.
trippydog
Re: Timing belt or "kit"?
Postby matthew2riches » Tue Feb 23, 2010 5:10 pm
I just replaced the belt on mine as the bearings in the tensioner sounded ok.
There's no harm in replacing it, then you know you've got a good one :)
matthew2riches
Postby steveselvage » Tue Feb 23, 2010 5:40 pm
I bought a kit today from motaquip for 44 quid, i dont know the price difference if i just bought a belt but i know how much damage a broken tensioner can cause.
Not worth the risk.IMO.
steveselvage
Postby Altransit » Tue Feb 23, 2010 5:59 pm
If you're not sure when, or if it was last done, then change the lot ....... water pump as well if funds will allow :wink:
Postby darkbluevanman » Tue Feb 23, 2010 8:20 pm
Altransit wrote:If you're not sure when, or if it was last done, then change the lot ....... water pump as well if funds will allow :wink:
Here... why do some state some water pumps as cast or alloy... is one better than the other?
darkbluevanman
Postby ZeldaTheWelder » Tue Feb 23, 2010 8:27 pm
When i had my can belt changed last year they changed the tensioners & rollers
as bearings were making a horrid noise. the new one was completly diffrent my friend
who done it questioned ford who said they had had trouble with old ones and upgraded them.
just my pennys worth :D
96 mk 4 smiley banana swb semi hi top
Mk6 swb low top with even more rust!
04 Connect T220 LWB.
ZeldaTheWelder
