cold start wire
cold start wire
Postby white transit man » Wed Feb 24, 2010 8:27 pm
where does the wire go that is on the back of my cold start, ive got the one that looks like a sausage with a wire going through it, please help,,, thanks..... :(
white transit man
Re: cold start wire
Postby Frag » Wed Feb 24, 2010 10:21 pm
Do you know how to post pictures ?
If your van is a 98 with an earlier engine,there won`t be any wiring for coldstart :?
The coldstart wire would come off the end stud on black part,go to a 2 terminal (temperature)switch in the block behind fuel filter,then into loom.(it is a +12V ignition feed)
Best try & post a picture :idea:
Frag
Ford Technician
Re: cold start wire
Postby white transit man » Thu Feb 25, 2010 6:21 am
thanks again frag...... ive noticed that there it 2 pin connector on the block with a red ring arond the bottom of it, if i connect the cold start wire to it how do i fit the other wire ( 12v one) cheers will try and post some pics if i can
white transit man
Re: cold start wire
Postby white transit man » Thu Feb 25, 2010 3:51 pm
how do you post pics on here ????
white transit man
Re: cold start wire
Postby djc151084 » Thu Feb 25, 2010 3:57 pm
white transit man wrote:how do you post pics on here ????
upload your pic to a site such as www.tinypic.com then post it here in the img quotes [/img]LINK HERE[img]
The Van = Ford Transit 100 "V" Reg (2000) 2.5d SWB Low Roof
Location = Tonyrefail (Rhondda Valleys)
djc151084
Re: cold start wire
Postby Frag » Thu Feb 25, 2010 8:38 pm
white transit man wrote:thanks again frag...... ive noticed that there it 2 pin connector on the block with a red ring arond the bottom of it, if i connect the cold start wire to it how do i fit the other wire ( 12v one) cheers will try and post some pics if i can
Right,one terminal of the switch you`ve found connects directly to the stud on the end of coldstart mechanism,
The other terminal which i assume is spare on your van,needs connecting to +12volt FUSED feed,which is only 12Volts when ignition is switched on.
(it doesn`t matter which wire goes on which terminal of block switch,it simply makes or breaks circuit.)
If your van did not have this coldstart mech fitted before and you are looking for an ignition supply 12v feed,either connect (via a fuse) into stop solenoid on pump,or there should be a 12volt ignition feed to wiper motor .
The coldstart itself doesn`t pull much current but a fuse is advisable as a matter of caution/safety. :!:
If you`re not sure,fire away with any more questions :)
Frag
Ford Technician
Re: cold start wire
Postby white transit man » Thu Feb 25, 2010 11:13 pm
ok so i plug the soliniod wire into the connector and get another piece of wire with a fuse in the middle and connect it to the same power wire as the wiper motor aswell as the connector, or could i just connect the fused wire to the block connector and then to the battery should that work?? anyway thanks so much for your time and help
white transit man
Re: cold start wire
Postby Frag » Fri Feb 26, 2010 4:20 pm
If you wire straight to battery,soleniod will be live all the time (if engine temp is above 11 deg) even with keys out,it really needs putting to an ignition feed,wiper motor or pump stop solenoid being easiest i can think of under bonnet. :idea:
Frag
Ford Technician
