2L petrol performance
Postby earthman » Thu Feb 25, 2010 3:34 pm
Do you guy's find that an early nineteen nineties 2L petrol will loose speed like a stone when you hit an hill? On steep hills it's that bad dropping from 70 to 40 that HGV's often overtake me.
The van will hit 85/90 on the flats no problem, just done a compression check and all cylinders are fine.
earthman
Re: 2L petrol performance
Postby rover » Thu Feb 25, 2010 5:46 pm
Pinto or DOHC engine?
Rover.
rover
Postby earthman » Fri Feb 26, 2010 3:45 pm
It's a single cam engine.
earthman
Postby Frag » Fri Feb 26, 2010 4:32 pm
What van is it in ?,more info may help us help you.
Body style,if its a luton bodied chassis cab or similar then its to be expected.
In fairness i don`t think any of the SOHC petrol lumps will be much cop up hill on motorways.
Especially if loaded !
Give it a service,plugs etc (set valve clearances) then check ignition timing & set co%
Not much else you can do really without doing mods.
Frag
Ford Technician
Postby tbird » Fri Feb 26, 2010 4:44 pm
Our pinto engined camper doesn't like hills, its ok if you can get a run up but once you loose momentum that its :lol:
2001 Mk6 90/330 Ex RAC Now with Vantuner re-map
_____________________________________________
tbird
Postby rover » Fri Feb 26, 2010 8:45 pm
Even mine will struggle up the steeper hills, and thats a heavily modified Pinto! I can be down to 55mph from 70 on occasion so I dont think you have too much to worry about, just dont expect too much from the old gal :wink: Tourque is not their strongest point :(
Rover.
rover
Postby earthman » Fri Feb 26, 2010 8:53 pm
OK, I'll have to come clean, it's a VW Transporter high top panel van which is actually a motorhome conversion.
It's the first petrol van I've ever driven, normally drive diesel vans in my work so I was not sure if the slowing down on hills was just a problem in mine, all four cylinders read the same, 150psi so it's healthy in that respect. I service it regularly, change plugs,filter etc. the co mixture is correct, it seems to run fine otherwise.
earthman
Postby Frag » Fri Feb 26, 2010 9:31 pm
Is it a type 25 ? what year ?
I`ve got an `82 aircooled panel van & a `69 bay window.
Had a few Veedubs,work for Ford but campers are my "bag" baby 8)
Frag
Ford Technician
Postby earthman » Sat Feb 27, 2010 9:14 am
It,s a 1992 type 4, first of the Transporters with the engine up front, in line.
earthman
