MurrayXmas wrote:Na the bulbs fine!! All lights work with ignition on but the nearside head light doesn't work with ignition off!!
dibs wrote:On my van, both the side lights come on with the ignition off and the lights turned on.
dibs wrote:True, but MurryXmas says he has checked the bulb. Maybe he should check it again with a new bulb.
Altransit wrote:dibs wrote:On my van, both the side lights come on with the ignition off and the lights turned on.
Yup, thats correct, but when you turn on the ignition, the headlights will come on dimmed, so if you have a faulty sidelight, you won't see it when the ign is on
