i think i have a grey gear selector problem as my gears are grinding 2nd and 3rd sometime 1st anyway i dont think its the clutch as there is no slipping.
first questing can i spray wd40 up the breather pipe or the reverse plug to see if its the selector sezied first.
second were and what way do you tighten the grey cableanit clockwise or clockwise. also do i need to count the turns if it makes it worse.
