rear axle on c reg transit
Postby tom_moran » Wed Feb 24, 2010 5:08 pm
hi all
im here to ask the experts! a friend has asked me to replace the rear axle on her c reg transit. now ive never worked on a transit before and before i go over and realise ive not got the right tools etc, i want to get it right first time basically.
ok first question is are the bolts to be used stretch bolts? as i know on some makes they are. im going to need to replace the diff oil but what oil and how much of it? and bleed the brakes up etc. anything else ill need to know? is there any tricks to doing these?
thanks in advance guys
Tom
tom_moran
Re: rear axle on c reg transit
Postby madmark » Wed Feb 24, 2010 6:46 pm
bolts are not strech as far as i know i allways re-use them,the diff oil is ep90 3 ltrs should cover it :wink: :wink:
goodluck :wink:
Postby tom_moran » Wed Feb 24, 2010 11:28 pm
nice one, thankyou very much. is there somewhere i can see pictures of what ill be working on? i know it seems odd but i wont get a chance to see the thing till it needs to be fixed.
i appriciate your help
tom_moran
Postby AlanN » Thu Feb 25, 2010 10:09 am
Whats wrong with the old one and what type is it?
Postby tom_moran » Thu Feb 25, 2010 10:12 am
the diff died, not sure what you mean by type? the van or axle?
tom_moran
Postby AlanN » Thu Feb 25, 2010 10:17 am
If it was type 34 (square section, used on the MK3 too) with diff problems, then just change the diff, very easy. You could even find a better ratio, but remember the speedo pinion gear for the speedo.
Postby tom_moran » Thu Feb 25, 2010 3:15 pm
im not sure what type it is tbh, ive asked her for pictures last night but she has no camera. i have the reg if that could help?
tom_moran
Postby MinorMatt » Thu Feb 25, 2010 3:42 pm
If there are 5 wheel studs it should have the easy to replace front loading diff, if it has 6 wheel studs an axle swap is easier
Postby tom_moran » Sat Feb 27, 2010 12:19 pm
ive just arrived and its five stud so ill just swap the diff over. Next question is how do i do that??
tom_moran
Postby madmark » Sat Feb 27, 2010 1:58 pm
pull both halfshafts and undo the prop,then undo all the nuts around the diff!
dont forget to have a bowl handy as oil will go everywere :wink:
Postby tom_moran » Sat Feb 27, 2010 2:59 pm
thankyou! Thats helped enormously. Hopefully this will be the last question, can a jack the van up on the diff? As im struggling to find places strong enough to jack it up and put axle stands under it. I dont want to bend the chassis as thats game over
tom_moran
Postby madmark » Sat Feb 27, 2010 3:20 pm
if you jack on the diff you will find the jack will get in your way,cant you jack on the axle????
Postby sidspop » Sat Feb 27, 2010 4:38 pm
Jack under the diff then put stands each end of axle.
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby tom_moran » Sat Feb 27, 2010 7:31 pm
i cant thankyou enough guys, i really cant. I got the spare diff ready to go in, the old diff still in place but completely disconnected and draining over night. Only thing ive left to do tomorrow is to work out a way to get the fill plug out as it mashed to bits and like every other bolt ive undone today was so coated in 20 years of rubbish ive literally had to hack away to find them then spend 2 hours with a wire brush and cleaner before they were in a fit state to be undone!
Ill drop back tomorrow with the result as i know its nice to hear the end to things.
On another note, if anybody ever needs advice or help on a vauxhall you can find me at mk3oc.com with the same username as hear and ill be happy to help in anyway i can
tom_moran
Postby madmark » Sat Feb 27, 2010 7:57 pm
glad to help mate, dont forget to do a nice gasket ,myself i would use sylicon sealer all the way round and that should stop it from leaking :wink:
