MK5 alternator differences
Postby shadyocuk » Tue Mar 02, 2010 9:00 pm
My p reg 1997 mk5 150 (none turbo) swb currently has a lucas 70 amp alternator with the 3 bolt on terminals. I would like to fit an uprated alternator and see that from mid 97 they changed to a bosch 95 amp. Am I correct in thinking that the alternator mountings and vaccum pumps are identical and that it is just the wiring connections that differ between the two types ?
If its that simple does any one have details of which wire goes where ? (I use all 3 wires on the current one as I fitted a mondeo rev counter cluster.) And is it very difficult to take the vaccum pump off the original and fit it to a new one?
To save anybody asking why I wish to fit a larger output alternator, my van has twin starting batts and 4x85amp leisures (with a stering B2B) and at times I tow a caravan that also has 4 leisure bats . So if the headlights and heated screen are on , not much charge will get to the leisure batts!!
Shady
shadyocuk
Re: MK5 alternator differences
Postby LRN » Tue Mar 02, 2010 10:19 pm
Vac pumps are different.. could still use but would also need to change associated piping to suit newer model.
Cabling ... main live bolts on same as currently [just on the back] .. smaller two have a multiplug connector that plugs into a socket on alternator ... you could no doubt 'adapt' the current wiring to fit [bit tricky though]
Yea all mounts are the same
HTH
LRN
Postby shadyocuk » Wed Mar 03, 2010 1:00 am
Thanks for the reply .
I reckon I could adapt the electrics easy enough , worst case I could get the multiplug conector from a scrapyard and splice into my existing wiring.
If the vac pumps are different , would the vac pump from a 70 amp lucas fit and work with a bosch 95 amp ? or would I have to use the newer type of vac pump and somehow adapt my existing piping.
Shady
shadyocuk
Postby LRN » Wed Mar 03, 2010 8:57 pm
You would need the later one .. comes as a whole alternator/pump assembly, unlike earlier model.
LRN
Users browsing this forum: dumper, Peterr
