tddi argh! advice please (finished 26/3/10) Thank you FTF
Postby belly » Wed Mar 03, 2010 10:08 pm
Well my 2.4 90 tddi didn't even last it's first week even after all the tlc it's had :evil: got a call today that the van has lost power sounds like it's missing and smoking! i wasn't nowhere near it so the guys had to carry on! had a look this eve and this is what it's doing! very tappy top endy but not diesel knocky, hesitant and sluggish sounds as if missing, blueish smoke,also on tickover it sounds like it's pumping out of the inlet but get it to about 60mph and it seems to smooth off and run ok! i've whipped the rocker cover off to see if the timing has jumped but i cant see any damage and all looks ok! could it still have jumped? secondly i'm thinking pump?or thirdly how about a pistonring? bloody thing cheers
belly
Kaiser Chief
Re: tddi argh! advice please
Postby mobilevanman » Wed Mar 03, 2010 10:11 pm
i may be wrong but it sounds possable u have an injecter going or worse a piston goning further testing to be done would include leakoff test on injecters and compression test on engine
good luck
tony
why not if u dont someone will
mobilevanman
Postby belly » Wed Mar 03, 2010 10:16 pm
Cheers i'm planning on doing a compression test! i thought the tddi injectors were ment to be bulletproof?
belly
Kaiser Chief
Postby AK » Wed Mar 03, 2010 10:18 pm
My 54 plate tddi 115ps one managed to snap a valve spring and it sounded just like you have explained, could be wroth checking the valve springs
Andrew
59 plate merc splinter Luton, 56 plate 100 TDCI 350 Crew/Camper conversion
AK
Postby belly » Wed Mar 03, 2010 10:20 pm
cheers AK will check that aswell! keep it coming lads :D
belly
Kaiser Chief
Postby coconut » Wed Mar 03, 2010 10:32 pm
Timing could have just jumped 1 tooth :idea:
But as the others say check simple stuff 1st like valve springs, rockers etc then I'd go for the compression test and see what that brings up :!:
Also check the cam to see if any of the lobes have cracked and are spinning on the cam
coconut
Ford Technician
Postby belly » Wed Mar 03, 2010 10:42 pm
Cheers Coconut you nearly got to look at it today! as it limped from your hometown! wish it had stopped there actually or fallen of the bridge :lol:
belly
Kaiser Chief
Postby belly » Wed Mar 03, 2010 10:45 pm
If it has jumped one tooth will it have damaged anything? i'm guessing the timing can only be checked with the front cover off?
belly
Kaiser Chief
Postby coconut » Wed Mar 03, 2010 11:05 pm
I was on a nice long roadtest today, so wasn't in the workshop for much 8)
If it has jumped 1 or 2 teeth very unlikely it would damaged anything :D but thinking again the earlier engines didn't jump :!: but it would have to have the front cover off to check but you could check the crank to pump timing and if that's slightly out then that's a good indication the timing has jumped :wink: but do check the basics before ripping it apart to much
coconut
Ford Technician
Postby belly » Wed Mar 03, 2010 11:10 pm
cheers well if you need another long roadtest feel free to head this way :wink: did i mention my brother in law is a manager for carlsberg and my father in law is a butcher 8)
belly
Kaiser Chief
Postby coconut » Wed Mar 03, 2010 11:14 pm
belly wrote:cheers well if you need another long roadtest feel free to head this way :wink: did i mention my brother in law is a manager for carlsberg and my father in law is a butcher 8)
what's your postcode :lol: :lol:
coconut
Ford Technician
Postby KH_Towbars » Wed Mar 03, 2010 11:25 pm
belly wrote:cheers :wink: did i mention my brother in law is a manager for carlsberg 8)
I'll help ya fix it mate :lol: :lol: :lol: :lol:
2016 CUSTOM LIMITED LWB Shadow Black
2010 VW CADDY MAXI 1.6TDi
SOLD VW T5 102 SWB
R.I.P MK6 FWD 2.0TDDI Duratorq, EGR mod, K&N air filter, 16"alloys
KH_Towbars
Postby belly » Thu Mar 04, 2010 9:25 am
I must admit are BBQ are good tons and tons of meat and the odd one or three broken cases :wink: :lol:
I've never had a front cover off yet! Can it be done without pulling the whole front off? I know this will give more room but I don't want to leave it where it is with all the front off if that makes sense :? Looks as though there's room if I drop the rad out ! :D
belly
Kaiser Chief
Postby jacko1611 » Thu Mar 04, 2010 8:09 pm
u can get the front cover off without takin the front end off. dont need the rad off either just the fan and fan cowling
not another E G F*****G R!
jacko1611
Ford Technician
Postby belly » Thu Mar 04, 2010 9:15 pm
cheers jacko :D had a quick look again whilst it was still light! and decided theres loadsa room :lol: also chaps im going to buy these bits and bobs are they the tools for the job?
http://cgi.ebay.co.uk/Laser-4066-Timing ... 3a584ee442
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
i know the tester is a cheapy :? what do you reckon?
belly
Kaiser Chief
Users browsing this forum: knobby1
