side lights
side lights
Postby peteman » Sun Mar 07, 2010 9:52 am
I have a 2001 tdci pick up which i cant get side lights working on.
head lights are fine,my question is do all the lights on the switch work from the same live cable ?.
I have removed the switch and can only find one live feed.
Is it common for the side light part of the switch to fail?
peteman
Re: side lights
Postby GBBiker » Sun Mar 07, 2010 11:45 am
The switch works from a common live feed but the sidelights and headlights are on different circuits thereafter.
There will be three circuits IIRC (plus another for main beam):
Sidelights & Tail lights
L/H Headlight
R/H Headlight
Have you checked the sidelight circuit fuse?
Do your tail lights still work? If they do, then it's not a fuse problem. More likely to be blown bulbs at the front or a break in the circuit.
GBBiker
Wrong Again!
Re: side lights
Postby peteman » Sun Mar 07, 2010 12:01 pm
Hi
I have ran a live feed from battery to fuse box and all lights come on,i then put live feed to rear of switch and lights came on again.
volt metre only shows one yellow and orange lead to be live.
Problem seems to be either in the switch or after it.
There are ten or so pins in plug but i have no idea what each feeds.
They are all numbered but i have no referance to check which is side lights'
Peter
peteman
Re: side lights
Postby GBBiker » Sun Mar 07, 2010 1:24 pm
peteman wrote:I have ran a live feed from battery to fuse box and all lights come on,i then put live feed to rear of switch and lights came on again.
This would suggest a switch problem then.
GBBiker
Wrong Again!
Re: side lights
Postby ake » Mon Mar 08, 2010 7:54 am
Have you checkedAll the fuses :?:
Re: side lights
Postby peteman » Mon Mar 08, 2010 9:11 am
All fuses and bulbs ok.
Any idea where to get wiring diagram to check loom?
ford quote £97 for new switch so would like to check wiring first.
peteman
Re: side lights
Postby GBBiker » Mon Mar 08, 2010 9:33 am
ake wrote:Have you checkedAll the fuses :?:
If he's
surely that would rule out a fuse problem :?
There is obviously power to the switch as the headlights work and there is obviously no problem from the fusebox onwards as the lights come on when he applies direct power.
To me this suggests either the switch itself or the feed from switch to fusebox.
GBBiker
Wrong Again!
Re: side lights
Postby mealic » Tue Mar 09, 2010 11:45 pm
Hi there,I have a working switch from an 04 plate mk6.A tenner plus postage if thats a help.PM me and I will be in touch.
`04 2.3 petrol/LPG
mealic
Re: side lights
Postby ake » Wed Mar 10, 2010 7:46 am
If he's
But on some vehicles, there are fuses after the switch :? So just thought I'd ask
Re: side lights
Postby GBBiker » Wed Mar 10, 2010 8:46 am
ake wrote:
If he's
That was my impression, based on the MK6s I have owned. The switch is fed with a direct supply and the fuse is between the switch and the load.
:idea: Having thought about it more, it must be the switch unit itself at fault :!:
GBBiker
Wrong Again!
Re: side lights
Postby peteman » Wed Mar 10, 2010 4:48 pm
Thanks for all your comments lads.
Fitted new switch today from breakers and all is well :D
Night driving back on thank god !!!
Peteman
peteman
Re: side lights
Postby TR4N51T » Wed Mar 10, 2010 10:36 pm
Hi guys, I have a similar problem whereby, I only have the H4 bulb working on the N/s lamp. Both the sidelight bulb and auto leveller doesnt work.
Do you think this could be a switch problem too? I've checked wiring which seems ok, and also checked another working lamp off a mates van and still same problem.
Thanks in advance, Chris.
TR4N51T
Re: side lights
Postby ake » Thu Mar 11, 2010 7:50 am
Have you checked all fuses :?:
Re: side lights
Postby GBBiker » Thu Mar 11, 2010 1:19 pm
yellowstonediesel wrote:Yellow stone diesel parts plant is one of the leading manufacturers
of engine parts, in particular diesel fuel injection system
accessories for replacement, such as Fuel injection Nozzle, Plunger and
Delivery valve, ETC In south of china .
for more detail please visit our website : http://www.yellowstonediesel.com
http://www.dieselinjection.cn
Yellow stone diesel parts plant was founded in 1997.Over the years,
Yellow stone has grown and gained a reputation for producing
high quality products and delivering them on time.
GTFO Spam monkey :evil: :evil: :evil:
GBBiker
Wrong Again!
Re: side lights
Postby AndyG » Thu Mar 11, 2010 8:35 pm
Luke wrote:You may have noticed odd posts from time to time on the forum - they are from automated spambots who post an advertising link on the fourm automatically :evil:
Do not click the links :!: :!: :!:
also do not reply to them, especially quoting them, as when they are erased all their posts dissapear but the post you have made quoting their link will still be on the forum :!:
just click the Report post to moderators button, this will bring the thread to the attention of a moderator and the posts will all be erased :D
Thanks 8)
cron
