Turbo Blown?
Turbo Blown?
Postby Davidkent » Fri Mar 12, 2010 7:10 pm
Hi guys.
I've a turbo here for my spare van that is no good.
I've just bought another one, from a reputable breakers, and have opened the parcel, only to find this one seems to be the same.
How do i tell that a turbo is no good?
When i look in the end, there's a fan like thing, on almost an axle.
This has loads of play in both the original, and the one i've just bought.
Is this how i can tell its blown?
Can i Re-con a Turbo myself?
Davidkent
Re: Turbo Blown?
Postby MinorMatt » Fri Mar 12, 2010 10:52 pm
What direction is the play in?
Re: Turbo Blown?
Postby winterheating » Fri Mar 12, 2010 10:55 pm
Davidkent wrote:Hi guys.
is the turbo of a mk6 :?:
when these turbos fail they become very noisy., its the way there designed, you can have quite a bit of play on some of them and they wil be fine.
winterheating
Re: Turbo Blown?
Postby Chris Honeywell » Sat Mar 13, 2010 10:27 am
side to side there should be a little bit of play in and out should be almost nothing
Chris Honeywell
Re: Turbo Blown?
Postby winterheating » Sat Mar 13, 2010 11:30 am
Chris Honeywell wrote:side to side there should be a little bit of play in and out should be almost nothing
is that your name or do you work for honeywell/garret :?:
winterheating
Re: Turbo Blown?
Postby Davidkent » Wed Mar 17, 2010 3:07 pm
Basically there's play all ways on the second hand one.
I've just taken it apart because it didn't look right.
The spindle on the manifold side has come off totally and been loose for some time it would appear that its been hitting the manifold or the like, the fins seem all snapped.
Can i re-con this myself, and where can i get the kit?
David
Davidkent
Re: Turbo Blown?
Postby John Grove » Wed Mar 17, 2010 9:20 pm
I got a kit off Ebay because my oil seals had gone and I was blowing blue smoke. Can't remember what was in the kit but did it ok. You need to make sure the armature is in balance I beleive. I think the hardest point on mine was removeing and refitting the huge circlip - after I'd soaked the whole thing in penetrating oil for a day to get it out of the manifold. Don't know if any of this helps. John G
John Grove
