Pinto valve stem oil seals
Postby Kelvfoozinda » Sun Mar 14, 2010 7:06 pm
Is there a way to change them without taking the head off?
Kelvfoozinda
Re: Pinto valve stem oil seals
Postby hornhead » Sun Mar 14, 2010 7:16 pm
Not that I know.
Put straight 40 or 50 oil in when spring arrives....smoke will stop...nearly...back to 20/50 in winter
til you're ready for head rebuild...
hornhead
Postby The General » Sun Mar 14, 2010 8:47 pm
They can be done but you will need a air line adaptor to pressurise each cylinder at a time with both valves shut. Then you need a tool to remove the valve spring. You could buy the tools or make your own like i did. I just copied the picture from an old haynes manual.
The General
Postby dumper » Sun Mar 14, 2010 9:42 pm
hi i have seen a tool to do it but it was a long time a go it my have snapon
Postby Kelvfoozinda » Sun Mar 14, 2010 10:40 pm
Someone just suggested that method on oldskoolford. Would be able to do it with a compression tester i spose, not that I have one at the moment. I'll take the head off and do it properly. Its got a lot of cam rattle, and i've got a 1600 head from my old capri that was silent, are they a streight swap for a bit more compression or am I thinking of something else?
Cheers, Kelvin.
Kelvfoozinda
Postby bortaf » Sun Mar 14, 2010 11:19 pm
Bit too mutch comp on a normal pinto but as yours is low comp? the valves are smaller on the 1.6 head as well :)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby bazw » Mon Mar 15, 2010 11:46 am
you can take the plugs out and feed rope in to the cylinder to fill up a bit then turn engine by hand to hold valve up in place , pop into gear to hold piston in place while working on valve
the one thing i cant remember is if you need the cam out to do this , if so you will need to pull the head as it comes out the back of the head :(
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby nicky d » Mon Mar 15, 2010 7:21 pm
there used to be a tool available for the pinto heads years ago that used to screw into the ball stud threads, also one thing to note, the 1.6 head also has longer valves than the 2 litre, personally I would pull the head off and change the cam and followers for the 1.6 ones, meant to give better performance on the 2.0.
Its fairly easy to change the camshaft bearings too, something I would consider doing unless your has the bronze bearings, as they seem to be a bit more resilient than the white metal ones. :wink:
2002 transit lwb semi
2000 kangoo
2003 mondeo "smoky"
nicky d
Postby Jim Archer » Mon Mar 15, 2010 9:49 pm
If the seals are leaking it quite often means the guides are worn as well.
Pretty sure most of the chamber volume is in the piston crown on the Pinto.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby nicky d » Mon Mar 15, 2010 10:07 pm
Yes the guides do wear quite badly on the pinto, but also the stem seals are weak and go brittle and then ride up the valve instead of clinging onto the guide top. a common conversion is drill out the guides, replace with guides of a slightly larger seal retainment diameter,(eq. to vag 96010) and use vauxhall cavalier fwd 8mm stem seals. As its a cheaper fix, a lot of people just prefer to change the stem seals :wink:
2000 kangoo
2003 mondeo "smoky"
nicky d
Postby bortaf » Tue Mar 16, 2010 12:19 am
Followers are the same so no point in changing them, there is a tool that fits under the cam, you really need compressed air feed to hold the valves up or the rope trick works fine :)
In the past i've done it with a long prybar but DO NOT get it anywhere near the lobes of the cam :wink:
It takes a while for the valve seals to harden and lift (IE years) i allways just use standard and not had a problem, appart from once with a cheap set of unknown make, 1 kept riding up so i had to change it after the rebuild (hense the use of the prybar and rope), never had a problem with payen or better seals, on some oval track engines i've seen CVH seals used with the plate the spring holds in place to stop the seals popping up at high revs but unessersary on a road engine IMHO.
The tool
head chamber volume is
1.6 - 37,5 to 40,5 cm'
2.0 - 48,6 to 51,6 cm' HC and LC but the LC engine has shallower piston crowns
if that helps at all ?
good to see Ford used fine tolerences for the head chamber sizes, you think they were done by hand :lol:
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby nicky d » Tue Mar 16, 2010 8:01 pm
bortaf wrote:good to see Ford used fine tolerences for the head chamber sizes, you think they were done by hand :lol:
british engineering at its finest :wink: :lol:
But what an engine -- used to love my mk3 cortina 2.0 pinto with a red painted engine and chrome rocker cover, weber carb and pancake filter :D
and my mk3 transit, capri and granada mk2 :oops:
there is just something about these engines........ :wink:
2000 kangoo
2003 mondeo "smoky"
nicky d
Postby ME » Tue Mar 16, 2010 8:16 pm
Many a word said in Jest.
I remember the days where we used to use a Buerete (spelling a long glass tube) to measure the Volume etc of the Formula Ford Pinto's my old boss used to build. They had to be spot on as we always had some one lodge a protest against the engine and ended up stripping it for the scrutineers :roll:
To be Honest the time it takes to remove a pinto head why mess around trying to do anything with it in situ :?:
Mercedes Vimto Premium
ME
Postby darkbluevanman » Wed Mar 17, 2010 7:17 pm
rope trick works, but you need the valve tool, I borrowed someones on a couple of occasions (genuine part!) but this should do the job... http://www.discounthandpowertools.co.uk ... e-ohv-ohc/
darkbluevanman
