no power
no power
Postby porkie » Mon Mar 22, 2010 7:27 pm
hi i hope someone can help me please
i bought a transit luton that had been stood for a while put a new back on it
paid to have cambelt new oil, filters etc inc fuel all done moted etc
have tried to use it but it has no power at all. the back is lightweight so no probs there
asked the garage and they say they can see no reason why but it wont do more than 40mph on the stright
the vehicle is a 98 model and i think it is the bosch pump that cant be turned up but not 100%
any ideas?
thanks in advance
porkie
porkie
Re: no power
Postby sideshow_bill » Mon Mar 22, 2010 8:16 pm
Timing springs to mind - either cam or pump?
sideshow_bill
Re: no power
Postby AndyG » Mon Mar 22, 2010 10:37 pm
:idea: brakes binding :?:
Re: no power
Postby porkie » Mon Mar 22, 2010 10:47 pm
hi thanks for the replys
just went stright through a mot so brakes should be ok and it does not smoke at all and starts 1st turn just no go at all :(
porkie
Re: no power
Postby AndyG » Mon Mar 22, 2010 10:55 pm
Re: no power
Postby porkie » Mon Mar 22, 2010 11:16 pm
hi again
i will try that in the morning
many thanks
porkie
porkie
Re: no power
Postby big mk5 » Tue Mar 23, 2010 1:23 am
if its not the timing, its possable it may be dragging in air to the fuel line somewhere?....my last car had a similier problem and it turned out to be 2 pinholes in the fuel line on top of the diesel tank.....is the acceleration ok...does it drive lumpy?
MY VANS NOT NOISEY...ITS JUST MY STEREO NEEDS MORE SPEAKERS
big mk5
Re: no power
Postby porkie » Tue Mar 23, 2010 8:42 am
hi
it will accelerate ok to 25mph then its real slow if i can get up to 40 ish mph when on the flat i have to change down to stay at that speed
regards
porkie
porkie
Re: no power
Postby big mk5 » Tue Mar 23, 2010 1:00 pm
did you drive it before the cambelt was done? does it stall?... i would check the timing 1st because thats the obviouse... then once you know the timing is spot on , start on the fuel system either a blockage or dragging in air from somewhere ....if you get a small clear inline fuel filter and put it before the original filter you can see if there are any air bubbles travelling in the pipe....run the van for 5 mins then look for bubbles...but make sure all the fuel line clips are tight and the fuel lines themselves are in good condition at the ends....i hope this helps
big mk5
Re: no power
Postby alanwh » Tue Mar 23, 2010 5:43 pm
Torque piston maybe stuck in its sleeve :!: quite common when they have been laid up for a while. try searching torque sleeve. youll have to take out the piston and give it a buff up :wink:
alanwh
Re: no power
Postby sideshow_bill » Fri Mar 26, 2010 10:25 pm
please let us know if/when you find the cure?
sideshow_bill
Re: no power
Postby Steve B » Sat Mar 27, 2010 2:16 am
as andyg says in the link, it should solve you problem
Steve B
Re: no power
Postby Jim Archer » Sat Mar 27, 2010 4:01 pm
Not if the torque sleeve is stuck it won't. Have to agree with Alan with this.
Other possiblity is the govenor sleeve is sticking and not moving up to cover the bleed off ports at higher revs.
Does it accelerate OK and then just stop? or is it dead slow (a relative term I know :lol: ) up to your 25ish?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
