I have spent a fortune on rocker cover gaskets over the years and they always seem to seep oil, mainly out the back end of the head/rockercover. Sides and front seem and generally to seal OK but the back is a pain, and I have never got it to seal properly.
I have tried sealant but that does not work, I have been trhough the pain of not having the right gasket at one point as there is a narrow one and a wide one (mine uses the wide cork seak), have also tried different tensions on the cover bolts and leaving the two tunnel bolts till last.
Can any one advise on a solution as I'm really doing my nut, as is the Mrs and thats a bad thing
Cheers,
Rich.
