Wheel Bearing Settings & Torque Advice
Postby Mauser » Wed Jun 28, 2006 8:34 pm
Could someone please let me know the size of the torque screws holding the hub on ?, I am replacing the wheel bearing but I need a long torque drive to undo and release the bearing, its the one for the 4 or 5 pins about 8mm in size ? have tried a 8 torque bit but this is to small, it fits but will slip under load.
Also what torque settings should I use for the wheel bearing and any others pins I tighten up.
I am changing discs and pads as well whilst I am @ it.
Thanks Simon
Mauser
Postby MrMPuk » Wed Jun 28, 2006 8:38 pm
Do you mean the Torx (star) bits?
Postby MrMPuk » Wed Jun 28, 2006 8:39 pm
What van do you have by the way?
Postby transitgeoff » Wed Jun 28, 2006 9:31 pm
always exercise extreme caution when tightening pins :lol: :lol:
transitgeoff
Postby Mauser » Wed Jun 28, 2006 11:01 pm
I have a 2001 "Y" Plate SWB 2.5 low roof but not sure if its turbo or not ?.
Very new to transits, first one so things are bigger than my Galaxy lol. Yes I do mean the torque star bits, need the size required to undo the little buggers and the correct settings to torque them back up if possible along with wheel bearing nut.
Thanks Simon
Mauser
Postby MrMPuk » Wed Jun 28, 2006 11:03 pm
Does the front look like this?
Postby 100ps_drw_hicube » Wed Jun 28, 2006 11:03 pm
mate yours is probably 2.o or 2.4 is it the latest shape i.e mk6?? fwd or rwd??
100ps_drw_hicube
Transit Abuser!!
Postby motorwise » Wed Jun 28, 2006 11:07 pm
your bearing kit will come with new bolts so you can get the size off them - most factors will have long pattern bits you can put in a ratchet for this - don't know the torques and I can't find my disc but tight for the bolts and very very tight for the hub nut :wink:
http://www.motorwise.net
motorwise
Postby MrMPuk » Wed Jun 28, 2006 11:09 pm
Hub nut is 200Nm, but's that's a Mk6 RWD, god knows what he has though!
Postby motorwise » Wed Jun 28, 2006 11:11 pm
MrMPuk wrote:Hub nut is 200Nm, but's that's a Mk6 RWD, god knows what he has though!
thats sounds good to me - must be a MK6 if he's got the torx bolts on the hub
motorwise
Postby MrMPuk » Wed Jun 28, 2006 11:14 pm
Could be FWD, but wont be a 2.5 and will be turbo.
Postby motorwise » Wed Jun 28, 2006 11:16 pm
MrMPuk wrote:Could be FWD, but wont be a 2.5 and will be turbo.
yeah he is a bit unclear about the engine - FWD and RWD hubs are the same I thought - could be wrong of course I usually am :lol:
motorwise
Postby Mauser » Wed Jun 28, 2006 11:31 pm
According to DVLA it was first registered 01-04-2001 and the engine is 2496cc and its FWD :), and yes the front looks like your picture. Just the turbo bit I am unsure of ?. If I know the torque size I can get 1 tomorrow but I cannot get the bearing till I know the spec on it ?, local spares shop didn't know the bearing sizes as I have a contact in the bearing service industry who can get 1 cheaper than the £20 I have been quoted.
Thanks for the info and hopefully you should be able to identify my vehicle.
Simon
Mauser
Postby motorwise » Wed Jun 28, 2006 11:35 pm
Mauser wrote:According to DVLA it was first registered 01-04-2001 and the engine is 2496cc and its FWD :), and yes the front looks like your picture. Just the turbo bit I am unsure of ?. If I know the torque size I can get 1 tomorrow but I cannot get the bearing till I know the spec on it ?, local spares shop didn't know the bearing sizes as I have a contact in the bearing service industry who can get 1 cheaper than the £20 I have been quoted.
Simon
if it's FWD the engine size is wrong on your log book it should be 1998cc - the bearing will be a bit dearer than £20 more like £85 it comes complete with the hub and the torx bolts are in the kit
motorwise
Postby MrMPuk » Wed Jun 28, 2006 11:36 pm
Something wrong there!!!
It will be turbo as all the Mk6s are!
