how to bypass a mk7 egr valve?
Re: how to bypass a mk7 egr valve?
Postby ake » Mon Mar 29, 2010 6:42 pm
Sounds like it should work, Winter will know for sure
Postby Guy88 » Mon Mar 29, 2010 7:04 pm
im goin to take the pipe off mine and blank it exhaust side and then remove the pipe to the inlet of the valve and run it round the block and try it our see wat it does
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ake » Mon Mar 29, 2010 7:26 pm
They can take a few miles to put the light on, might have to run it for a day to know for sure
Postby winterheating » Mon Mar 29, 2010 7:54 pm
Guy88 wrote:are we any further on this?
iv been thinking about this and all i can see is that it needs the exhaust side blanked and the inlet side routed to the air filter, from wat i can tell is on boost it should be closed anyway :?: :?: :?:
so wat i was thinking is disconnect and blank the exhaust side
route the inlet side to the air filter and possibly fit a one way valve to it to only allow air in rather than boost out :?
that will never circulate as there will always be more boost from the egr (boosted side after turbo) than were it tees in before turbo,the non return would be permantly closed.
winterheating
Postby winterheating » Mon Mar 29, 2010 8:00 pm
as you know the way i had it on the mondeo the boosted air was going backwards through normal direction of EGR, and i had it connected to the air feed to turbo, this didnt loose any boost and kept all sensors happy that exhaust gas was recirculating.
but upset the crankcase breather.
i'm sure it would be perfect if it were connected into boost pipe straight after turbo compressor :idea:
as the pressure at compressor will be higher than at the inlet manifold very slightly, enough to cause circulation.
is the EGR on the mk7 near inlet manifold aswell :?: :?:
winterheating
Postby winterheating » Mon Mar 29, 2010 8:07 pm
i have also maybe found an easier way to blank |EGR without bringing light on or causing a fault code......
winterheating
Postby ake » Mon Mar 29, 2010 9:02 pm
Egr is below inlet on MK7, above starter
Whats your new plan :?:
Postby winterheating » Mon Mar 29, 2010 9:48 pm
after id connected pipes as shown in pics, noticed crankcase pressure was getting to high, as i had the rocker pipe disconnected, i thought i could just put a tee in the new pipe work to hopefully suck on the breather.
this didnt work and all oil seals p**sed out still.
so i then removed my pipe from rocker cover and the other side of tee piece from the turbo inlet pipe, i just connected turbo feed pipe back onto rocker cover as standard, and left my new tee piece in and just connected both ends back on themselves.
left everything else connected as it should be , so basically it was now just the same as EGR blanked but about 1.5metres of rubber hose instead of a blanking plate.
suprisingly the light didnt come back on after a few days, so i disconnected egr vac pipe, and after a while light came on, then connected vac tube back up and light went off :shock: :shock:
i thought, it would at least give fault codes but a ford guy with all the righ ford equipment couldnt find any fault codes.
all i can think is the rubber hose is allowing a slight drop in air flow and boost, a bit like a pressure vessel. and its enough to satisfy pcm.
its been like this since 1.3.09
been using everyday aswell.
winterheating
Postby Guy88 » Mon Mar 29, 2010 10:07 pm
im goin to just balnk mine, i cant see a MAF on my 110 ps :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby coconut » Mon Mar 29, 2010 10:12 pm
Guy88 wrote:im goin to just balnk mine, i cant see a MAF on my 110 ps :D
it's got a maf, on the intake pipe from air filter to turbo :!:
coconut
Ford Technician
Postby Guy88 » Mon Mar 29, 2010 10:18 pm
little square bit with a plug on that bolts in, i assumed it was an intake temp sender :lol:
when is the EGR actually open :?:
im guessing all the ECU needs to see is a drop in air flow at the MAF when the EGR is open :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby coconut » Mon Mar 29, 2010 10:23 pm
The temp sensor is part of the map (tmap) sensor :wink:
The egr is constantly varying the amount it's open depending on the throttle position, load demand and boost pressure :!:
coconut
Ford Technician
Postby Guy88 » Mon Mar 29, 2010 10:26 pm
coconut wrote:The temp sensor is part of the map (tmap) sensor :wink:
So these have MAP and a MAF sensor :?
I take it the square with the plug in the inlet is the MAF
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby coconut » Mon Mar 29, 2010 10:33 pm
yep, they have the maf in the intake pipe with the square black
plug with little red tab and the tmap is in the elbow that bolts to the inlet manifold :!:
coconut
Ford Technician
Postby Guy88 » Mon Mar 29, 2010 10:39 pm
so somehow i need to increase the pressure on the inlet to the EGR to just over boost pressure,
i cant see how increacing the length of the pipe is any different to just blanking it with a check valve to only allow air in :? :? :? :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
