captain hook wrote:I should have a set in the "cave" if you need them![]()
Hi again captain how much with postage thanks Chris
chrisf1 wrote:captain hook wrote:I should have a set in the "cave" if you need them![]()
AlanN wrote:Ok I'll help...
you won't find any regulator on the back of the MK3 clocks, as it built into the pair of dials... So if both have failed, you need to check that the assembly is being feed by (black/green pin 5. 12vdc) which then feeds both dials.
The negative supply is feed by :-
FUEL(blue/black pin 4 -vdc supply) and
TEMP(red/white pin10. -vdc supply)
Check this with you AVO meter on VDC and the ignition on, Im not sure what volts you get, as Ive never measured it. If the volts are OK, then you need to change the pair of dials, easy enough to do, just 4 nuts on the back of the clocks.
Please let us know how you get on.
Yes MK3 petrol ones will work, same assembly, different speedo
OK Jim, how about thisJim Archer wrote:AlanN wrote:Ok I'll help...
I did say on the back of the gauge/dial(s) itself, not the back of the clock unit/head. Several times![]()
Not to worry, sounds as if you've got it sorted anyhow.![]()
Jim
