15x10 BACK WHEELS ON A MK5
Postby newyorkdrummer » Tue Mar 16, 2010 5:54 pm
Hi Has anyone put a set off 15x10 steel wheels on a mk5 before.I just bought a set for my van Im putting 15x8 on the front and 15x10 on the back these are landrover steel wheels im having redrilled.I know I will need wider rear archs has anyone got a picture for me.Thanks Colly
newyorkdrummer
Re: 15x10 BACK WHEELS ON A MK5
Postby Luke » Tue Mar 16, 2010 6:03 pm
we NEED pics of these when they are fitted 8) 8)
Postby AlanN » Wed Mar 17, 2010 1:17 pm
You might have to have a look at Transittrev's thread to cover them over I recon
viewtopic.php?f=14&t=62160
Postby newyorkdrummer » Wed Mar 17, 2010 3:44 pm
Thanks Alan.yea im fitting transit connect plastic arches on the back.Im trying to find off road tyres for the rear.My problem is i go diving on the weekend and i have a 6.5 metre rib and sometimes i find it hard to pull the boat out the stock tyres just sink in the sand.I know i need a 4x4 transit but Im also a motorcycle mechanic i use the van for picking up bikes and the 4x4 is too high.
P.s. Love your van
newyorkdrummer
Postby newyorkdrummer » Sun Mar 28, 2010 2:41 pm
Hi guys need help with tyre size.Whats the largest size tyre that will fit a mark 5 rear 15x10.
Landrover tyre if possible thanks Colly
newyorkdrummer
Postby MinorMatt » Sun Mar 28, 2010 7:40 pm
Have you tried letting some (most of) air out of the tyres?
If you want to fit 15x10 on the back I would be inclined to fit a mk3 rear axle - which is narrower than the mk5
Postby Choppergeoff » Wed Mar 31, 2010 11:05 am
MinorMatt wrote:Have you tried letting some (most of) air out of the tyres?
Hey Colly. In the 80's I had a Bedford CF.. LWB and fitted a chevy Camero rear axle ,with a pair of 10x15 Woolfrace
wheels (ltd edition ) and did'nt need any arches . why not look at Heavy duty American Ford car axles?
cheers Geoff
I don't do Standard and I don't do Normal...whatever that is
[url]Past vans [/url]1966 Mk 1 V6 3.0ltr Camper. 1982 Mk 2
9 or 10 Mk 3/4/5's
current ...Customised SHR LWB twin SLD Door Chopped roof Turbo D
Choppergeoff
Postby darkbluevanman » Fri Apr 02, 2010 6:31 pm
newyorkdrummer wrote:Hi guys need help with tyre size.Whats the largest size tyre that will fit a mark 5 rear 15x10.
I'd not worry too much about the width, possible problem could occur with height, though there's some pretty wide low prof tyres about...
darkbluevanman
Postby Gavin-T » Sat Apr 03, 2010 8:09 pm
Try here for the tyres
http://www.camskill.co.uk/products.php?plid=m64b0s227p0
Not sure if they will fit width wise in your arches but they should be ok for the rim. They are a 4x4 tread pattern too and not overly expensive :D
Just as a thought.......
Could you not put some mk6 15" rims on and use some 15" 4x4 tyres? http://www.camskill.co.uk/products.php?plid=m26b0s496p0 Skinny tyres are better than wide tyres 95% of the time when off roading as they can cut through the soft mud to the firm ground below.
Gavin.
Gavin-T
Postby pat stevens » Thu Aug 26, 2010 10:22 am
Ive got 10 x 15 cragar slot mags on the back of my s reg and 8 1/2 on the front using 25mm adapters
i went the old school route for the arches 10mm steel tube then plating them in with steel took me a lot of work and still not exactly finished to how i want em but certainly turns heads wherever we go tyres are 265 50 15 0n bk and 225 60 15 on front only problem i had was had to take the taper off the front outriggers and make them square like a mk 1/2 easy job to make tyres clear ive tried 17s 18s on but to be honest although they look great i carry a lot of equipment long distances and was always replacing tyres usually every couple of weeks. as for pics of my van id love to put some on here but i havnt got a clue how and as im not a computer buff the instructions go right over my head now all as ive got to do is work out what to do with the side loading door it only opens about 2 inches now
if its got tits or wheels its always gonna end in trouble !!!
anyone can restore a van but it takes a real man to chop it up !!!
pat stevens
Postby AlanN » Thu Aug 26, 2010 10:49 am
I saw a pair of BFG 275/55/15 for 19.99 on ebay last week while looking for my 14's they fit 7.5 to 9.5 " wide rims, plus they didn't sell
I have chart here, I can email it if you want, plus try this calculator http://www.tyresave.co.uk/tyresiz2.html
Postby Luke » Thu Aug 26, 2010 9:31 pm
pat stevens wrote:as for pics of my van id love to put some on here but i havnt got a clue how and as im not a computer buff the instructions go right over my head
i'd love to see them - can you email them me and i'll post em up 8)
Postby ginsambo » Fri Aug 27, 2010 6:38 am
PICS!!! Love to see these fitted! :D
Pat got any pics of the mags??? PICS PICS PICS! :D
Love to see some pics!
My Mk5 was biodegradable and disintegrated with time.
Ford. Committed to the Environment
Finally entered the 21st Century and bought a MK7. Oh Dear.
ginsambo
Postby pat stevens » Fri Aug 27, 2010 5:40 pm
working on how to put pics on (well to be honnest the mrs is i aint got a clue) will try and be at transit mania next sun (oh my god that means i gotta clean the van and get rid of the rubbish from inside lol)
pat stevens
Postby ginsambo » Sat Aug 28, 2010 9:36 am
http://cgi.ebay.co.uk/EXTREME-OFFSET-MO ... ar_Rims_ET
Searched for landrover modular wheels and loads come up! :D 8J's, No 10J's though! :lol: But no commercial tyre will fit one will it?
ginsambo
