help fitting seats in lwb 190
Postby T reg TKR » Wed Mar 31, 2010 1:49 pm
hi all, great site
i have just got a plylined 1999 lwb 190 transit and want to fit 2 extra seat in the rear
has anyone done this or know of a step by step guide ?
need help cheers
btw picking up the twin seat tomorrow, also what size bolts will i need ?
Been a Transit man since 1999.
T reg TKR
Re: help fitting seats in lwb 190
Postby T reg TKR » Wed Mar 31, 2010 2:08 pm
i know i'll have to take up the plylined front part of the floor, just want to know are there holes for the bolts etc
T reg TKR
Postby doughythevanman » Wed Mar 31, 2010 5:21 pm
Hiya !!
There may be a thread on here somewhere :? but if you cant fine one i would find some 5 mm steel plate ( 8 pieces ) with a hole in the middle for the bolt to go through. Mark and drill your holes taking care not to get anywhere near brake pipes etc. I used 17 mm nuts and bolts on mine and use nice big washers on each side. Use the steel on each side ( i.e. inside the rear and underneath ) and you will need a friend to hold a spanner underneath while you inside tightening. Hope this helps!!!
P reg SWB Semi high top
S reg LWB 190 Semi high top
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby T reg TKR » Wed Mar 31, 2010 7:46 pm
cheers nice help, i did a search but didn't look hard enough i guess.
yeah found 2 holes ready for bolts so just need to make 2 more,
thanks for the heads up on the metal plates and the bolt sizes.
T reg TKR
