Dare i ask ~ TRANSIT HEATER RESISTOR
Postby Jon Boy UK - Wales » Wed Mar 31, 2010 6:46 pm
Hello All,
I replaced the TRANSIT HEATER RESISTOR thanks to the info in the forum!
I do have a query though!! What colour wire goes where ?
The three wires are no longer in the blaack connecting block they are loose and each have spade connector on the end
I have tired allsorts of combinations my Heater fan switch works on no 1 and 2 only. I'm woundering if theres a bad connection somewhere...
I would like to know though the definitive answer of what wire goes to what pin?
Could some one draw me a diagram ?
Violet/Yellow
Violet/Blue
White/Green
Kindest Regards,
John Gray
Transit 1995 MK5 ~ Series: 120 - SWB Hi-roof ~ Engine: Diesel 2.5 (70PS)
Jon Boy UK - Wales
Re: Dare i ask ~ TRANSIT HEATER RESISTOR
Postby Backbone of Britain » Wed Mar 31, 2010 8:29 pm
Have you checked if your switch is ok and actually works on position 3. They some times burn out when the resistor is knackered being set to position 3 all the time.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby Jon Boy UK - Wales » Wed Mar 31, 2010 8:39 pm
Hello,
All the connections to the switch are ok nothing loose or melted ..As for the number 3 setting i don't recall it ever working on number 3
The switch only worked on just the one speed (number 2 ) before i replace the resisitor now it works on nmber 1 and 2 but not three. Thats why i want to make sure i have the right coloured wire on the right pin before i go on from there.
I was expecting my van to get warmer quicker ... Could it be the thermostat ?
Jon Boy UK - Wales
Postby Backbone of Britain » Wed Mar 31, 2010 9:06 pm
If it never worked on position 3 when the old resistor was in place then the switch is knackered as the resistor only comes into play on positions 1 and 2. Try a new switch.
Backbone of Britain
Postby Jon Boy UK - Wales » Thu Apr 01, 2010 9:22 am
Hello
Many thanks for your help and continued support...
Yes i'll buy a new switch!
Now back to the other question part..... what colour wire goes on what pin ?
Kindest REgards,
John
Jon Boy UK - Wales
Postby Backbone of Britain » Thu Apr 01, 2010 12:03 pm
On my swb where the resistor is under the bonnet the wires are:
With the resistor facing so the single spade connection is at the top and the two at the bottom.
Green/White cable to the top
Purple/Yellow to the bottom left
Purple/Blue to the bottom right
Backbone of Britain
Postby Jon Boy UK - Wales » Thu Apr 01, 2010 6:59 pm
Hello,
Excellent Many Thanks...I also replaced the thermostat ... My heaters are boiling :D
Kindest Regards,
John
Jon Boy UK - Wales
Postby Backbone of Britain » Thu Apr 01, 2010 7:21 pm
Glad I could Help :D
Backbone of Britain
