injectors
injectors
Postby len robo » Fri Apr 02, 2010 10:27 pm
hi i have a 1996 transit 190 luton box van need new injectors can i fit 70ps ones and will they be ok ,,,
len robo
Re: injectors
Postby MinorMatt » Fri Apr 02, 2010 11:01 pm
you need to fit the correct injectors for you pump. So you MUST fit whatever is currently fitted
Re: injectors
Postby len robo » Sun Apr 04, 2010 10:00 am
thanks for your reply..been offerd set of 70psi but mine are 76psi so ford tell me ..would i be able to get them reset....
len robo
Re: injectors
Postby MinorMatt » Sun Apr 04, 2010 12:20 pm
You need the 76PS injectors then. AFAIK you cant get them recallibrated, just "reconditioned!
cron
