MPG
MPG
Postby tmlockton » Mon Apr 05, 2010 9:32 am
Have got a 2006 transit, LWB, High Top, 135 T350, 2.4cdi. Cannot get any better than 28mpg contary to manuals figures.
tmlockton
Re: MPG
Postby foggy08 » Mon Apr 05, 2010 10:40 am
i drive a 135 t350 luton and it doesnt get better than 20 mpg......and thats checked monthly over a 2 year period
ouch ..suarez bit my finger
foggy08
Re: MPG
Postby angeleye » Mon Apr 05, 2010 11:00 am
manual gives 32 average so your not far out, 25-28 on my jumbo 135, what axel you got
angeleye
Re: MPG
Postby winterheating » Mon Apr 05, 2010 11:40 am
tmlockton wrote:Have got a 2006 transit, LWB, High Top, 135 T350, 2.4cdi. Cannot get any better than 28mpg contary to manuals figures.
blank EGR, that will give gains straight away, use ford fomula e 5w-30 oil, aswell replacing filters, smash cat out (with no EGR it wont be required as much anyway), use some good fuel BP ultimate or shell vpower, and/or some good fuel treatment.
check injector correction factor codes are programmed in correctly this can make a huge difference.
check for split boost pipes, slight leaks can cause turbo to work a lot harder loose efficiency.
check all tyre pressures, check no brakes are sticking on, specially after a good run.
check diff oil,gearbox oil.
winterheating
