non starter after bump ?
Postby office95 » Fri Apr 09, 2010 9:28 am
HI. I have a 51 reg 2.0l td swb transit, I`ve had a bump at front not to bad but now won`t start, light next to clock flashes fast and engine will not turn ? is their a cut off or somthing. light flashing code 15 can anybody help please.
office95
Re: non starter after bump ?
Postby micknew » Fri Apr 09, 2010 11:21 am
I think the light next to the clock is something to do with the immobiliser, I might be wrong.
micknew
Postby angeleye » Fri Apr 09, 2010 7:07 pm
try disconnecting battery for an hour or so,see if it will reset itself,sometimes you might have to leave it over night,is it turning over,or just not doing any thing,what damage was caused in accident
angeleye
Postby ake » Fri Apr 09, 2010 9:16 pm
Have you checked under bonnet that no wiring is damaged/fuses blown
Postby office95 » Sat Apr 10, 2010 9:19 am
will try disconnecting the battery later. The damage was bumper, bonnet and radiator.
Not turning over and brake light on dash comes on when key is turned to start position.
office95
Postby ake » Sat Apr 10, 2010 9:28 am
Check wiring at starter, this is behind radiator, may have been damaged
Postby AndyG » Sat Apr 10, 2010 10:07 pm
Is there not an automatic immobilizing cut off switch that can be reset, should you be involved in a bump :?:
Check above both front wheel arches inside the cab :idea:
Postby office95 » Mon Apr 12, 2010 11:56 am
checked all wiring no faults, when key is turned to start position the brake light on dash lights up and engine does not turn and light in clock flashes fast ???
office95
Postby Altransit » Mon Apr 12, 2010 12:18 pm
Code 15 is, I think, unrecognisable key :? Do you have 2 keys :?:
Postby office95 » Mon Apr 12, 2010 12:26 pm
Hi, no i only have 1 key lost the other, what would you recommend ??
office95
Postby Altransit » Mon Apr 12, 2010 12:33 pm
Maybe check around the ignition barrell, to see if the receiver is damaged. This reads the code from the key
Postby office95 » Mon Apr 12, 2010 12:53 pm
will i have to get spare key coded to vehicle and if so do i need to take it to ford or is their someone mobile that can do this job ??
office95
Postby office95 » Tue Apr 13, 2010 2:07 pm
still not starting, is there anyway of bypassing the immobiliser, This is becoming a pain in the backside.
51 reg transit 2.0 td
office95
Postby AndyG » Wed Apr 14, 2010 12:28 am
Give an auto locksmith a call :idea:
Postby office95 » Sat Apr 17, 2010 9:26 am
got locksmith out, coded two new keys and job sorted, Thanks to everyone for your replies and comments.
office95
