Turbo injectors
Turbo injectors
Postby Eugene Speed » Sat Apr 10, 2010 8:16 pm
Found a LWB TDi in the scrappy today, the sticker on the timing belt cover said 100ps, would this be an ideal engine to nick the injectors from as I'm going to do a turbo engine conversion on my County. Already secured myself a turbo lump complete but it is from a SWB so I'd guess it to be 80ps? I have the Bosch 145 pump ready, will using the 100ps injectors give me a bit more grunt? Or should I look for new/recon/uprated injectors?
91 Transit County 4x4
88 Transit 130 armoured van
99 Transit spec lift
90 Fiat Panda 4x4
http://facebook.com/eugene.speed
http://tuffcomputercompany.com
http://transitcounty4x4.co.uk
http://truthsearchersuk.org
Member of the Mk3 Massive! :)
Eugene Speed
Re: Turbo injectors
Postby MinorMatt » Sat Apr 10, 2010 8:45 pm
Grab em
Especially if its a van made after '97
Re: Turbo injectors
Postby jay » Sat Apr 10, 2010 9:36 pm
lowest turbo is 85ps then 100ps then 115ps and if really lucky (130ps but this might have been marine engine only)
mk1 connect tourneo
jay
Re: Turbo injectors
Postby MinorMatt » Sat Apr 10, 2010 9:37 pm
130 is marine only.
115PS is rocking horse poo and you can tell it is because it has a factory fit intercooler.
Re: Turbo injectors
Postby AndyG » Sat Apr 10, 2010 10:02 pm
And the 115PS intercooled smiley uses 100PS injectors :wink:
Re: Turbo injectors
Postby gardener68 » Tue Apr 13, 2010 9:43 pm
MinorMatt wrote:Grab em
what is the difference with 100ps injectors pre and post 97 please
gardener68
Re: Turbo injectors
Postby MinorMatt » Tue Apr 13, 2010 9:50 pm
the pressures they operate at. The post '97 ones are higher pressure
Re: Turbo injectors
Postby gardener68 » Tue Apr 13, 2010 10:09 pm
would there be any advantage for me to switch to the later injectors on my 1995 "145" td.
gardener68
Re: Turbo injectors
Postby MinorMatt » Tue Apr 13, 2010 11:19 pm
I wouldnt worry if its running well as it is
