2000 model gearbox trouble
Postby bluecraig0776 » Thu Apr 08, 2010 9:38 pm
Hi folks just a wee quick question. My friend has a 2000 model transit which he has difficulty selecting 2nd and reverse gear and sometimes it jumps out of reverse gear. Any ideas? Apparently the gearbox was reconditioned before he bought it.
bluecraig0776
Re: 2000 model gearbox trouble
Postby jay » Thu Apr 08, 2010 10:05 pm
FWD or RWD what engine 2litre or 2.4litre..if FWD then try readjusting the gearstick cables as the cables streatch..
mk1 connect tourneo
jay
Postby bluecraig0776 » Tue Apr 13, 2010 7:38 pm
Hi it's fwd 2.0
bluecraig0776
Postby jay » Wed Apr 14, 2010 1:22 am
try the cables first
mk1 connect tourneo
jay
Postby flyingclutchman » Wed Apr 14, 2010 7:34 pm
If the cable adjustment does'nt fix it, it may be the bearing in the top of the selector turret seizing up. This stops the shaft moving up and down freely. Can be fixed comparitivly easily
flyingclutchman
Postby bluecraig0776 » Sun Apr 18, 2010 9:27 pm
Had a look at the van today and cables seem ok. Have found that gear lever can be pressed down through every gear. Should this not only happen for reverse?
bluecraig0776
Postby ake » Mon Apr 19, 2010 7:39 am
Did you actually adjust cables :?:
Postby jay » Mon Apr 19, 2010 9:40 am
my gear stick will push down as well when in any gear as well.
Have you checked the cables and the bit on the gearbox??
mk1 connect tourneo
jay
