Hi guys
As some of you may know im fitting the 100ps td engine out of my old van which had all the epic egr stuff, my question is can I get away with removing all of the egr stuff as im using the bosch pump manual pump ? eg the egr valve itself and the other butterfly body and connect the pipe for the intercooler straight to the turbo, as it will make my life plumbing up the intercooler a lot easier and hopefully gain a few extra bhp. Hopefully that makes sense, I can take some pics of the bit im on about if it helps.
Cheers Andrew
