Mk 7 Paint problems, Warranty?
Postby sharpy » Fri Apr 23, 2010 3:35 pm
I have a mk7 07 transit van, I have got spots of rust coming out at the rear wheel arch front near the bottom, where it gets all weathers, Will this be covered under waranty?
sharpy
Re: Mk 7 Paint problems, Warranty?
Postby Mike » Fri Apr 23, 2010 5:13 pm
On the near side? Ford didn't bother painting that bit on the MK7 for a few years. Problem is that unless you've had the paint inspection done at service time you're a bit stuffed.
Mike
Wind up merchant!
Postby AndyG » Fri Apr 23, 2010 10:42 pm
The corrosion warranty is only valid if it's perforated from inside out :roll:
You would preferably have had the annual paint inspection with your service :roll:
And if the vehicle has had any paintwork done since it left the factory (other than by Ford) then the warranty no longer applies :evil:
