Any chance of more power from a mk5 2.5td?
Postby alexthecheese » Sat Apr 24, 2010 10:21 am
Any chance of more power on these? Being 2880kgs ulw and about 3300 in current spec the 100bhp has to go quite far. Is there any easy ways of getting power, or making sure its producing as much as it should?
alexthecheese
Re: Any chance of more power from a mk5 2.5td?
Postby AndyG » Sat Apr 24, 2010 11:25 pm
100PS should be powerful enough :!:
Check the wheels aren't binding and that your tyre pressures are correct :idea:
Postby psv-hgv-flt » Sun Apr 25, 2010 4:37 pm
alexthecheese wrote:Any chance of more power on these? Being 2880kgs ulw and about 3300 in current spec the 100bhp has to go quite far. Is there any easy ways of getting power, or making sure its producing as much as it should?
intercooler and tuning box. :wink:
psv-hgv-flt
Postby alexthecheese » Mon Apr 26, 2010 10:49 am
Andyg wrote:100PS should be powerful enough :!:
Binding? Rubbing together? I will have to check the pressures but they are not bulging too much. I did an oil change and air filter change on Saturday, that helped a lot. Definitely much perkier now - the air filter itself was really clogged up. :x
I don't think I can get a tuning box for mine, can I? It's carb isn't it?
What's the EGR bypass that I keep reading about, does that apply to my van? :?:
alexthecheese
Postby trigger » Mon Apr 26, 2010 11:07 am
Diesels don't have carbs they have injectors
Mk5 Transit the daddy
trigger
Postby alexthecheese » Mon Apr 26, 2010 12:23 pm
trigger wrote:Diesels don't have carbs they have injectors
Oh right, didn't know that. :? Is this EGR bypass going to be up my street in that case? :?:
alexthecheese
Postby trigger » Mon Apr 26, 2010 12:39 pm
I read that if you do the EGR bypass on the Turbo engines the ECU will make the engine management light come on as if there is a fault, fine to do on non Turbo engines tho
trigger
Postby psv-hgv-flt » Mon Apr 26, 2010 7:05 pm
trigger wrote:I read that if you do the EGR bypass on the Turbo engines the ECU will make the engine management light come on as if there is a fault, fine to do on non Turbo engines tho
no it don,t come, just blank it or if it is closed pull vac pipe off.
psv-hgv-flt
Postby ake » Mon Apr 26, 2010 8:00 pm
Blank it off properly, pulling the pipe off will cause it to log a fault every time you start it.
You can get a Tunit tuning box for Epic Transits
Postby psv-hgv-flt » Mon Apr 26, 2010 8:03 pm
but it will still run 100% with pipe off. easy.
psv-hgv-flt
Postby alexthecheese » Tue Apr 27, 2010 12:49 pm
Epic as in Epic fuel pumps? I've looked on Tunit's website and it looks like I can get a tuning box to get it from 100bhp > 120bhp and 185lb/ft > 215lb/ft. £422 though, so that's pretty steep.
Think it'd be worth it? Being a bus the gearing is pretty low, so I don't think I'd see any extra speed, just more grunt throughout.
Also, I guess this will reduce reliability...? :?
alexthecheese
Postby bazw » Tue Apr 27, 2010 3:39 pm
more power does not mean more speed , just qucker to get there
the revs need to go up or the gearing in the diff changed to make the bus go faster top end
total re-engineered pump and engine to make more revs safely so another diff is the way to go
or change to petrol engine to get more revs
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby alexthecheese » Tue Apr 27, 2010 4:08 pm
I think changing the diff sounds a bit extreme for me, considering the bus is fine as it is. But... is it literally just a case of changing the diff to make it rev lower, hence potentially increasing top speed/economy? Do all transit diffs fit all transits? My bus is a six wheeler.
I was thinking that more power would deal with hills better, which is why I was asking in this thread, but can you change the diff easily to get more speed?
The fuel pump looks like it's very new, is it a lot shinier and cleaner than the rest of the engine.
alexthecheese
Postby psv-hgv-flt » Tue Apr 27, 2010 7:37 pm
no it don,t come, just blank it or if it is closed pull vac pipe off.[/quote]
You can get a Tunit tuning box for Epic Transits[/quote]
Also, I guess this will reduce reliability...? :?[/quote]
i sold one of the tunit boxs on hear for that spec i think it went for £150.00..? , and yes they are over priced
psv-hgv-flt
