1968 LWB Twinwheeler 2,6 V6 project
Re: 1968 LWB Twinwheeler 2,6 V6 project
Postby spitfire » Fri Mar 19, 2010 4:19 pm
Southerner wrote:Looking lovely under there now! Real pain to do but very satisfying when done - what will you dowith it: paint, underseal? Cheers, Andy
First sandblast everything, then epoxypaint everything,sealer in the gaps etc, straightening of the outside then filler and painting.
Underseal am I not sure of but clear wax will be done.
Ketil
Ketil
Norway
ketil.frengen@norgespost.no
2,9 Cosworth V6 1968 mod LWB Twin wheeler
viewtopic.php?f=27&t=49610
spitfire
Postby spitfire » Fri Apr 16, 2010 6:38 pm
Old underseal gone now :D Clean underside is a good thing :D
Ketil
Norway
spitfire
Postby spitfire » Tue Apr 20, 2010 5:56 pm
Ketil
Norway
spitfire
Postby madmark » Wed Apr 21, 2010 1:45 pm
good work ,it is going to be very nice when it is finished :wink:
Postby spitfire » Thu Apr 29, 2010 4:20 pm
Need a bigger fuel tank so I thought why not take two small and combine into one big :D Over 100Litres should do it.
Ketil
Norway
spitfire
Postby AlanN » Thu Apr 29, 2010 5:40 pm
Blimey!!! a months wages to fill that bugger
Postby madmark » Thu Apr 29, 2010 6:01 pm
AlanN wrote:Blimey!!! a months wages to fill that bugger
:lol: :lol: :lol: :lol: :lol:
Postby spitfire » Thu Apr 29, 2010 8:14 pm
:lol: :lol: Yes thats thrue, :lol: but the V6 engine is a bit thirsty :roll: :wink:
Ketil
Ketil
Norway
spitfire
Postby spitfire » Wed May 05, 2010 5:29 pm
Started with testmounting the Power steering today
Ketil
Norway
spitfire
Postby spitfire » Wed May 05, 2010 5:37 pm
Mounted the engine and gearbox again because need to figure out if there is enough space (engine mounted 7 cm rearwards)
And figuring out where all the small bits etc will get mounted
Ketil
Norway
spitfire
Postby ztorm » Wed May 05, 2010 6:38 pm
Good job done! Keep us posted bout the power steering in detail! Well, me anyway :lol: :wink:
Still (t)rust in my Tranny
www.ztorm.nl
ztorm
Postby transitandy » Wed May 05, 2010 6:55 pm
mmm mmm very nice transit and great thread :D :D 8) 8)
Postby spitfire » Wed May 05, 2010 7:32 pm
ztorm wrote:Good job done! Keep us posted bout the power steering in detail! Well, me anyway :lol: :wink:
Ofcourse I can post some detail :D Had to grind out some of the pedal box and custom make up a new mount in the front of the Power steering.
Have dissambled the steering box and cut and modified the steering (rod? not sure what it is named) because of the new parts, the steering wheel mounted directly to the original splines of the Power steering :lol:
Modified the top part below the steering wheel so I can mount the original mk1 covers and mk1 flasher/dip switch to the Power steering.
Can take some detail pictures when it is done if you want.
Modified the gearlever also with some homemade stuff on the original gear lever and modified a mk2 gearlever to fit :D
A lot of fabrication
Ketil
Ketil
Norway
spitfire
transitandy wrote:mmm mmm very nice transit and great thread :D :D 8) 8)
Thanx :D
Ketil
Ketil
Norway
spitfire
Postby ztorm » Thu May 06, 2010 6:24 pm
spitfire wrote:Ofcourse I can post some detail :D Can take some detail pictures when it is done if you want.
Ketil
Well that would be very much appriciated Ketil! Thanks! :)
www.ztorm.nl
ztorm
