Vehicle Details Needed.
Postby bodgit0_0 » Fri Apr 30, 2010 9:51 am
Hello all, looking at parting company with my current van as Im collecting its replacement on monday evening.
Before I sell/scrap the old one I want to know what parts may be of use,rear axle if the ratios are the same, gearbox, engine etc that would be worth saving and scrap the rest.
The VRN of the old one is J890 GHY
The VRN of the new one is L808 SRP
Lee
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
86 Maestro MG Turbo conversion
89 Maestro MG Turbo '#370'
90 Maestro MG
90 Montego MG Turbo Conversion
88 Montego MG Estate 'F700'
94 Transit 4x4 Donor
99 Transit 4x4 LWB
bodgit0_0
Re: Vehicle Details Needed.
Postby nokites » Fri Apr 30, 2010 9:54 am
The J reg is to early for etis
Transit 92, Diesel 2.5 (80PS), Diamond White 73
VIN Number: SFALXXBDVLPP76579
Registration Number: L808SRP
Registration Date: 28.02.1994
Registration Country: GB
Primary Features
Build Date: 15.06.1993
Vehicle Line: Transit 92
Cab Style: Regular Cargo Van
Series: 190L
Engine: Diesel 2.5 (80PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.14
Emission: EEC 5TH Emission Requirements
Territory: (+)"GB"
Paint: Diamond White 73
Interior Fabric: Saturn
OLD CHINESE PROVERB
Man who works for nothing and women who f****s for nothing ---------ALLWAYS GOT PLENTY TO DO
nokites
Postby bodgit0_0 » Fri Apr 30, 2010 10:02 am
Many thanks, can you just edit the last 6 digits out of the chassis number as people can apply for a logbook with these detail.
Didnt know you could gain so much info from just the VRN.
Will now go and look at my J plate to see what diff is fitted.
Cheers again
Lee
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
90 Maestro MG
99 Transit 4x4 LWB
bodgit0_0
Postby madmark_50484 » Fri Apr 30, 2010 10:13 am
bodgit0_0 wrote:Many thanks, can you just edit the last 6 digits out of the chassis number as people can apply for a logbook with these detail.
Cheers again
Lee
Is your J reg a mk3 or mk4 as this will make a difference to compatibility if you post your vin for it you can find out on etis.
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Postby bodgit0_0 » Fri Apr 30, 2010 10:14 am
OK, the rear diff on my J reg has a plate with the following details.
92VB LAD
463 T51A
What does it all mean???
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
90 Maestro MG
99 Transit 4x4 LWB
bodgit0_0
Postby bodgit0_0 » Fri Apr 30, 2010 10:17 am
Mk 4 I believe.
viewtopic.php?f=7&t=61789
Lee
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
90 Maestro MG
99 Transit 4x4 LWB
bodgit0_0
Postby nokites » Fri Apr 30, 2010 10:29 am
L =51A Heavy Salisbury (less L.S.D)
P =51A Heavy Salisbury (with L.S.D)
The 463 could be your ratio check your chassis plate
Code Ratio
J = 5.14
K = 5.83
L = 4.56
N = 4.11
P = 5.13
G =4.63
OLD CHINESE PROVERB
nokites
Postby madmark_50484 » Fri Apr 30, 2010 10:32 am
Yes indeed MK4 providing they both have the same amounts of studs you can still use the diff even if its a different ratio :D and I would guess more or less everything else will be compatible.
Past
Present
www.busesuk.co.uk
madmark_50484
Postby bodgit0_0 » Fri Apr 30, 2010 10:37 am
Needs to be the same ratio as the later one is a 4x4 hence trying to confirm details.
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
90 Maestro MG
99 Transit 4x4 LWB
bodgit0_0
Postby MinorMatt » Fri Apr 30, 2010 10:38 am
Ahh its a county. In which case almost all the running gear is different - you could use the engine and the leaf springs, but thats probably about it!
Postby bodgit0_0 » Fri Apr 30, 2010 10:40 am
Bugger, I might as well tidy the arches on the old one and sell her on then.
Was hoping the rear axle would be the same at least.
Lee
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
90 Maestro MG
99 Transit 4x4 LWB
bodgit0_0
Postby bodgit0_0 » Fri Apr 30, 2010 10:44 am
Axle code is LG, so its a 4.63 which is of no use.
Will start some minor jobs to prep it for sale.
Cheers for all your help.
Lee
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
90 Maestro MG
99 Transit 4x4 LWB
bodgit0_0
