MK 6 Banded Steelies
Postby dan83590 » Fri Apr 30, 2010 2:31 pm
I'm seriously thinking about having this done to the 16 inch wheels fitted to my van. Not too wide, I want them to stay inside the arch.
I was wondering if anyone knows the max size I could have them made or what and where I should measure to find out for myself.
What about steering also, I don't want anything rubbing?
Any clues from you guys?
dan83590
Re: MK 6 Banded Steelies
Postby Luke » Fri Apr 30, 2010 5:36 pm
drop a plumb line down the side of the arch and measure the gap :idea: make sure the vans on level ground tho :D
sounds a good idea post some pics up and let us know how far you can go :D
Postby 93fxdl » Fri Apr 30, 2010 10:23 pm
here is a site where you can play with rim widths and diameters and tyre widths, aspect ratios and diameters
http://www.willtheyfit.com/
have fun
ttfn glenn
93fxdl
Postby belly » Sat May 01, 2010 10:00 am
they would look good 8) pop onto retrorides forum there's a guy on there that does them :wink:
belly
Kaiser Chief
Postby dan83590 » Sun May 02, 2010 9:14 am
Any suggestions of how wide I should get them made?
dan83590
Postby Luke » Sun May 02, 2010 9:19 am
dan83590 wrote:Any suggestions of how wide I should get them made?
drop a plumb line down the side of the arch and measure the gap have them fill the arch i've seen mk6's with wheels sticking out of the arches so you shouldn't have any rubbing issues - just get them made as wide as legally possable :mrgreen:
Postby dan83590 » Tue May 04, 2010 3:57 pm
The maximum I can add to the wheel is 1.5 inches. That will bring the wheel level with the standard arch. The size of the wheel will increase from 5.5J to a 7J.
Now, I wanted to go with a lower profile tyre also but I am finding it hard to find the correct size combined with an acceptable load rating. I was thinking maybe a 215 or 225 tyre with a 55 - 65 profile.
What do you chaps think?
dan83590
Postby darkbluevanman » Thu May 06, 2010 8:31 pm
darkbluevanman
Postby darkbluevanman » Thu May 06, 2010 8:35 pm
What's the std size?.... these may be better, if not cheaper!
http://cgi.ebay.co.uk/215-65-16-WANLI-1 ... 53db94c601
darkbluevanman
Postby dan83590 » Fri May 07, 2010 8:27 am
Standard profile is 75mm.
One of the reasons I want to do this is to try and make the steering feel a bit less like a rudder!
dan83590
Postby turbodoctor » Fri May 07, 2010 9:42 am
ive got a set on mine they look mint pal!!
THATS YOUR PROBLEM SIR YOUR TURBOS FELL OFF !!!!
turbodoctor
Postby dan83590 » Fri May 07, 2010 11:46 am
Now were're talking. Can put up a picture or email one to me? admin@ess-propertyservices.com
dan83590
Postby MrMPuk » Fri May 07, 2010 3:19 pm
dan83590 wrote:Now were're talking. Can put up a picture or email one to me? admin@ess-propertyservices.com
He already has.
viewtopic.php?f=6&t=63701&p=548647#p548647
Postby dan83590 » Fri May 07, 2010 4:07 pm
Why thank you MrMPuke. :mrgreen:
What bands were added and what tyres are fitted?
dan83590
