hmm change pump.. or change whole lump
Postby acarpen9 » Mon May 03, 2010 10:33 pm
Hi.. again.
3 probs fixed, another one comes.. and bigger each time.
Now have fuel pissin out the Lucas Cav pump, getting bit sick of entire system, more leaks than a collinder, Lump now near refuses to start and cuts out a short time after firing up. Effectively no van at minute.
So, am toying with ideas, first of all, where the leak is from is it just a repairable seal on the shaft? Starting to consider the costing of buying another Lucas Cav pump, cost of fitting, on what is a tired engine is it really worth it, what will die next..... would it be more cost effective to buy a newer banana lump and have that fitted instead..
Have you guys upgraded a lump rather than continuing to battle against Lucas Cav pumps, or is it cost effective to switch to a bosch injector setup, bearing in mind I have to factor in labour costs, as not sure how to do such things.
Thanks again
andy
If it has four legs and is not a chair, has wings and is not an aeroplane, or swims and is not a submarine the Cantonese will eat it
acarpen9
Re: hmm change pump.. or change whole lump
Postby MrMPuk » Mon May 03, 2010 10:40 pm
That's the wrong pump for that engine anyway, it should have a Bosch pump.
Postby acarpen9 » Mon May 03, 2010 11:07 pm
Plot thickens.... Reg Doc says it's auto petrol. A mere identity crisis, or bas*ard offspring of Satan??
acarpen9
Postby Altransit » Mon May 03, 2010 11:12 pm
That engine looks like mine, a 70ps Di, but the Lucas pump is a bit of an oddment as they haven't used them since the Mk4 :?
Postby jay » Tue May 04, 2010 8:20 am
with that inlet manifold it should have a bosch pump..more than likely its had a engine and box change then if it say auto and petrol on the log book..
mk1 connect tourneo
jay
