2.5d Turbo won't start
Postby calaistt » Sat May 01, 2010 3:29 am
Hi there guys, First time poster..
I have a 95 transit 2.5 turbo, Driving along nicely then water pump belt snaps off with a bang, i instantly loose power- engine only idles now.I roll down the hill and park.Vehicle is towed.Next day i try to start it but it just turns over.From the sound of it the engine it has compression.Continuous starting does nothing- no smoke .If i open throttle to wide open within 10 seconds it tries to fire but never makes it.The EPIC pump was removed and replaced with a bosch mechanical unit over a year ago and has never missed a beat.The pump has power and when i crack the pipe to the injector i get diesel being pump out there.Nothing else looks damaged in anyway. This problem does not make any sense. Can anybody shed some light here
Thanks Oliver
calaistt
Re: 2.5d Turbo won't start
Postby psv-hgv-flt » Sat May 01, 2010 4:02 pm
mabe a bit of belt has got in the timing belt and made it jump out a tooth.?? check timing.
psv-hgv-flt
Postby calaistt » Sun May 02, 2010 1:27 am
Thanks will check timing, however i tried to start it with a can of engine starter(25% ether) which should give me a partial fire but no luck there.
calaistt
Postby sideshow_bill » Sun May 02, 2010 8:50 pm
calaistt wrote:Thanks will check timing, however i tried to start it with a can of engine starter(25% ether) which should give me a partial fire but no luck there.
Not if the cam has slipped - wont be getting enough compression. you may have bent pushrods so not getting the inlet valves opening?
sideshow_bill
Postby calaistt » Mon May 03, 2010 9:31 am
Ok checked timing- camshaft out by many teeth.Fixed that, checked push rods-All eight rods bent like bannanas.Off too get some more and a spare head as well. Thanks to both you guys for your help.Hard to get help here in OZ..... 8)
calaistt
Postby sideshow_bill » Mon May 03, 2010 5:36 pm
you may be able to straighten the pushrods - I have done it before!
sideshow_bill
Postby psv-hgv-flt » Mon May 03, 2010 8:35 pm
sideshow_bill wrote:you may be able to straighten the pushrods - I have done it before!
:roll: WTF. :roll:
psv-hgv-flt
Postby sideshow_bill » Mon May 03, 2010 9:11 pm
:roll: WTF. :roll:
Yes indeedeedy siree - you of rolling eyes! And the van went on to run many thousands of miles - so save it!
sideshow_bill
Postby bodgit0_0 » Mon May 03, 2010 9:20 pm
I agree, try straightening them first. I have had success with both Transit and a Land Rover engine that had suffered a cambelt failure.
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
86 Maestro MG Turbo conversion
89 Maestro MG Turbo '#370'
90 Maestro MG
90 Montego MG Turbo Conversion
88 Montego MG Estate 'F700'
94 Transit 4x4 Donor
99 Transit 4x4 LWB
bodgit0_0
Postby psv-hgv-flt » Mon May 03, 2010 9:23 pm
:roll: WTF. :roll:
plenty of di,s out there with cheap parts without compromising on reliability for the sake of low price parts.
psv-hgv-flt
Postby bodgit0_0 » Mon May 03, 2010 9:34 pm
Yes you would be silly to compromise on reliability but its a simple metal rod that should stay reliable once straightened.
The Land rover ones were changed as the MOD are a big company and it is good practise to fix properly, the transit was mine and threw its gutts out about 3 months later due to motorway madness at silly revs in a Landy.
I always improvise to check there are no other faults hidden away.
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
90 Maestro MG
99 Transit 4x4 LWB
bodgit0_0
Postby sideshow_bill » Tue May 04, 2010 9:50 pm
I suppose it comes down to understanding what goes on inside an engine rather than just changing parts as per the book!
I once welded up the cylinder head of a Landrover after it had burned away between the 2 middle pots. It wasnt that I realy wanted to but we were stuck in a field in the middle of Glastonbury festival and getting a replacement head wasnt an option. I ended up filling the finger sized hole with rods then skimming it flat with a 4" grinder, and checking it with a steel ruler. (Did manage to get a new gasket)
The plan was to get the Landy and its caravan a respectful distance from the festival before calling the RAC for a tow home. But the engine was still going strong 2 years later when it was changed for a V8!
sideshow_bill
Postby calaistt » Wed May 05, 2010 12:27 am
Hi again,
I changed all 8 rods-got it all back together and she starts and runs but it does blow blue/black smoke now and has a terrible miss between 1000-2000 rpm.Power is down and boost has dropped from 18psi to about 14 psi. I will take the head off and see how bad the valves are...Oliver
calaistt
Postby calaistt » Wed May 05, 2010 4:58 am
Sorry white and blue smoke... Can't start it cold without some engine start spray.. Turbo is off and when i crank it white smoke from all 4 exhaust ports.
When she is warm it starts ok and will idle perfect- but still white smoke-not as much as when it is cold though...
Oliver
calaistt
Postby psv-hgv-flt » Wed May 05, 2010 8:24 am
have you set valve-clearences up.??
psv-hgv-flt
