Advice needed!!
Advice needed!!
Postby doughythevanman » Wed May 05, 2010 12:00 pm
Hello all,
After doing the EGR mod around a month ago and turning the pump on a little ( 1.25 turns ) i was going to put it back to normal as the MOT is coming up. I turned the pump back, took the blanking plate out and took the tie off the egr but when i started the old girl up it wouldnt rev high and was billowing out heavy smoke! :shock: :shock: It was vibrating like hell and most of the road had a heavy fog !!! When i tinkered with it i found that by opening up the egr flap again cured the smoke and vibration straight away!! :? :? What have i done and is there a reason for this???? :? :? :? :?
Thanks for any help!!
P reg SWB Semi high top
S reg LWB 190 Semi high top
Range Rover TD6
Volvo S80 D5
doughythevanman
Re: Advice needed!!
Postby doughythevanman » Wed May 05, 2010 12:04 pm
OOOPPPSSS !! Sorry, it a 98 ( s ) 190 LWB with the banana engine. Was fine before the mod so cant understand what is going on!! :? :? :roll:
Range Rover TD6
Volvo S80 D5
doughythevanman
Re: Advice needed!!
Postby madmark_50484 » Wed May 05, 2010 12:12 pm
Did you remember the connecting rod as without this the engine isn't getting enough air
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Re: Advice needed!!
Postby doughythevanman » Wed May 05, 2010 12:38 pm
:oops: :oops: :oops: :oops: :oops: :oops: YES!!!! :oops: :oops: :oops: :oops: :oops: :oops:
Range Rover TD6
Volvo S80 D5
doughythevanman
Re: Advice needed!!
Postby doughythevanman » Wed May 05, 2010 12:39 pm
problem solved! cheers mark!! 8) 8)
Range Rover TD6
Volvo S80 D5
doughythevanman
Re: Advice needed!!
Postby doughythevanman » Wed May 05, 2010 5:21 pm
Do i have to reset it back to normal for the MOT gas test? I was under the impression it would run cleaner with the egr mod thus going through the test easier :?
Range Rover TD6
Volvo S80 D5
doughythevanman
Re: Advice needed!!
Postby MrMPuk » Wed May 05, 2010 5:23 pm
doughythevanman wrote:Do i have to reset it back to normal for the MOT gas test?
No you wont.
Re: Advice needed!!
Postby Altransit » Wed May 05, 2010 7:23 pm
Mine goes through the MOT every year, with the EGR disabled, and the pump turned up :D
Re: Advice needed!!
Postby doughythevanman » Wed May 05, 2010 7:36 pm
Well the EGR and pump are now remodded :D :D cheers mpuk and altransit!!
I had read somewhere that to pass the test they would need to be put back to normal? :? Nevermind :roll: Just got to finish off welding me inner sills then it's time to get her MOT'd!!
Range Rover TD6
Volvo S80 D5
doughythevanman
